C450/C43 AMG
Largest tire on stock 19" rim
Old Feb 12, 2020 | 03:55 PM
1Gunner's Avatar
2020 C43 sedan(hers), 2021 Porsche 992 TurboS(his)
Question Largest tire on stock 19" rim
What have folks successfully used as largest oversize tire on stock 19" MB rims?
Old Feb 13, 2020 | 03:32 PM
batman719's Avatar
2019 C43 AMG Coupe
+1, interested
Old Feb 13, 2020 | 03:59 PM
alexasa's Avatar
c
the sock size. cause that's the widest that's within spec of the width of the wheels.
Old Feb 13, 2020 | 04:02 PM
1Gunner's Avatar
I have gone over-size on Porsche wheels and tracked them extensively without any issue. Why would MB be any different especially on a street vehicle?
Old Feb 13, 2020 | 04:07 PM
alexasa's Avatar
c
without any context whatsoever, it's hard to say.
Some manufacturers equip a 9.5 and put a 255 on it from the factory, meaning you could upsize to a 275. THat's not the case for at least the 19 inch wheels on the c43.
Old Feb 13, 2020 | 06:34 PM
1Gunner's Avatar
What context do you use to support the contention it's not doable?
Old Feb 13, 2020 | 07:59 PM
threeMBs's Avatar
Only MBs - the best or nothing
If you want to run a wider tire than stock' 225/40, say 235/40, on stock's front 7.5" wide wheel, then you we're given the answer above - max tire's width is limited by wheel's width - 225/40-19 is the widest tire that is recommended to be fitted on any 19x7.5 wheel. Minimum recommended wheel width for 235/40-19 tire is 8". Same for the rear - the widest recommended tire on 8.5" wide wheel is 255/35 (265/35 requires 9" wide wheel).
Old Feb 13, 2020 | 08:07 PM
alexasa's Avatar
c
literally tire manufacturers spec sheets. 255 is the widest, within spec, on an 8.5. sure you can put a wider tire on an 8.5 the same way you can stretch a much smaller tire on an 8.5.
there is no benefit to running a 265 on an 8.5 - you get excessive tire bulge, the tire will roll over easier and your contact patch is not effectively larger.
Old Feb 14, 2020 | 09:57 AM
1Gunner's Avatar
Thanks for the input, I see now where MB and Porsche owners differ greatly.
