The Instrument Display is explained in the owner's manual starting on page 213 and in the AMG supplement starting on page 25. I'm not sure if everything is there, but I find the instrument cluster quite self-explanatory. The temps are pretty straight forward. The two main ones that are shown in multiple places are the transmission temp and the oil temp. Then there is the coolant temp and the tire temps. That's as far as temps goes. The different layouts have things in different places. Supersport has the less important pieces of information hidden away in separate displays. To see the coolant temp for example you have to go to Service and then Coolant, but instead you can see the transmission and oil temps in several locations. I use the Supersport view and generally have the tire pressure screen on the right, which shows me most of the car's relevant health information. Tire pressure, tire temps, oil and transmission temp. It even colors the engine and transmission in blue on the diagram while they are cold, so I can quickly see if the car has reached operating temperature yet.
