C450/C43 AMG
One side light on?
Old Apr 8, 2020 | 09:14 AM
wsboxer1's Avatar
2018 AMG C43 Coupe
One side light on?
In the garage this morning I noticed a faint light against the wall. I though it was the suns reflection at first but then noticed that my passenger side marker light is on? Not sure what could be causing that, this can't be normal. I got back from the office early afternoon yesterday and have not moved it since. Also I keep my key in the office which is a good 25 feet from the car.
Edit - I did start the car and then turn it off The light remained on while the other side was off.
Driver side
Passenger side. Little light in the middle
Old Apr 8, 2020 | 11:22 AM
batman719's Avatar
2019 C43 AMG Coupe
Is your right standing light switched to on?
Old Apr 8, 2020 | 11:55 AM
wsboxer1's Avatar
2018 AMG C43 Coupe
I am not certain what a right standing light switch is. Lights are set to Auto and no turn signals or anything are on. Actually taking it into service this afternoon since I am free.
Old Apr 8, 2020 | 11:57 AM
batman719's Avatar
2019 C43 AMG Coupe
Owner's manual, page 114. However, if your lights are set to Auto, then this is not the problem. Definitely something else going on. Hope it's a quick and painless diag and fix for you!
Old Apr 8, 2020 | 12:05 PM
mo11's Avatar
2017 C43
Old Apr 8, 2020 | 01:28 PM
wsboxer1's Avatar
2018 AMG C43 Coupe
Ah, well thank you. Heading in soon and will update with what was found!
Old Apr 13, 2020 | 10:46 AM
wsboxer1's Avatar
2018 AMG C43 Coupe
Just as an update to this, they ended up replacing the front SAM control unit and things are back to normal.
Old Apr 13, 2020 | 12:22 PM
lkchris's Avatar
'10 CL550, '12 GL550
Front SAM failure is fairly common and really random things can occur. Most often it’s because the SAM got wet.
