C450/C43 AMG
JB4 Questions
Old May 12, 2020 | 02:54 AM
SukhmanC450's Avatar
2016 C450 AMG
JB4 Questions
2016 C450
How important is it to log your car 1-10??
How often should I do it??
I know I heard you can run up to 35% E85. Is that ok for a stock car??
Old May 12, 2020 | 09:31 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
Log 1-10...no idea what you're talking about?
You can blend E85 with regular pump gas. If you're filling a full tank, no more than 5gal of quality E85. I've run at least 35,000mi blended this way trouble free, almost 46k on the car. Edit: all of this on a custom map6 with BCM.
Old May 12, 2020 | 12:44 PM
2016 C450 AMG
I meant out of 1 to 10 how much do you recommend logging the car. And how much difference does the BCM module make from map 5 on 5 gals and how does it work
Old May 12, 2020 | 02:09 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
No need to log unless you want personalized tuning advice or to see how it's running. The JB4 has active safety systems so it will revert to a safety map on its own if things get too out of whack anyway.
