C450/C43 AMG
Need Help With JB4
Old Jun 29, 2020 | 09:22 AM
PxcesYT's Avatar
Mercedes C43
Need Help With JB4
I have a 2020 C43 and I installed just the JB4 mod and I didn’t feel any difference at all. Fortunately I talked with Terry and I got a Boost Control Module. I’m hoping this works will plan to set it all up the first of July. Also if anyone else has a 2020 C43 with a JB4 did you have the same problem?
Old Jun 29, 2020 | 11:01 AM
gabemcclintock's Avatar
2019 C43 AMG
Had a 2019 with a JB4 and sold it because of this very thing...didn't feel much in terms of gains like I did on my 2018. Would love to know how it feels for you once you get the BCM installed. Was told by Terry that adding the BCM would bring it back to the gains felt with the pre-facelift models.
Keep us posted.
Old Jun 29, 2020 | 03:59 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
BCM is a big difference maker for the facelift models.
Old Jun 30, 2020 | 01:32 AM
c43PDX's Avatar
C43 AMG
How does the BCM work? Is it controlled via the hand held or bluetooth? I'm probably going this route until AMR can get an update for the 2020.. How much WHP/WTQ gain should I expect with the JB4 on the 2020's? Do we have more potential than the PFL with the bigger turbo's? Are stock internals pretty strong for more boost?
Old Jun 30, 2020 | 11:44 AM
BMS's Avatar
BMS
2018 C63 Sedan
The BCM plugs in to the JB4 harness and in to the easy to reach boost solenoid so the JB4 can adjust wastegate dutycycle directly rather than having to reply on the mapped-too-low factory tables.
Old Jul 2, 2020 | 05:29 AM
PxcesYT's Avatar
Mercedes C43
So I’ve installed the BCM and JB4 still don’t feel much of a difference. Maybe it’s too early to tell. Does anyone know when I can use Map 2 do I need something additional to use Map 2 properly?
Old Jul 2, 2020 | 05:30 AM
PxcesYT's Avatar
Mercedes C43
Would you know how much psi I should be pushing in terms of map 0, map 1 and map 2?
Old Jul 2, 2020 | 06:48 AM
TModelle's Avatar
C190
Very first post on the BMS forum.
https://www.n54tech.com/forums/showthread.php?t=28003
Old Jul 2, 2020 | 09:50 AM
batman719's Avatar
2019 C43 AMG Coupe
What firmware are you running?
Old Jul 2, 2020 | 10:22 AM
1Gunner's Avatar
2020 C43 sedan(hers), 2021 Porsche 992 TurboS(his)
I have a 2020 with JB4 installed.
I am curious about getting a BMC.
Does it require constant adjusting and monitoring or is it simply plug it in and play?
Old Jul 2, 2020 | 11:43 AM
batman719's Avatar
2019 C43 AMG Coupe
* BCM.
It's plug-and-play. It connects just like the other connectors from JB4 going to the MAP sensors.
Old Jul 2, 2020 | 12:34 PM
1Gunner's Avatar
Originally Posted by batman719
* BCM.
Ok thanks.
So, once it is installed it requires no further adjustments?
Old Jul 2, 2020 | 12:36 PM
batman719's Avatar
2019 C43 AMG Coupe
Ok thanks.
Right. If it were me, I would run logs and send them over to BMS for a sanity check, but there is no further manual adjustment needed for the stock maps. If you are working with BMS toward a custom map, that's a different story. Make sense?
TModelle's Avatar
C190
Ok thanks.
It does not require any adjustments.
Old Jul 2, 2020 | 04:36 PM
PxcesYT's Avatar
Mercedes C43
I’m currently running the JB4_MB_C_4.hex
Old Jul 2, 2020 | 04:39 PM
batman719's Avatar
2019 C43 AMG Coupe
That's the correct firmware. Strange you are not seeing any difference. I would reach out to BMS support via email if I were you.
Old Jul 2, 2020 | 04:40 PM
PxcesYT's Avatar
Mercedes C43
Question do you mind sending me some map 0 and map 1 tests and also when did you start running map 2?
Old Jul 2, 2020 | 05:01 PM
BMS's Avatar
BMS
2018 C63 Sedan
As far as I know still waiting to see his map0 and map1 logs I requested above.
Old Jul 2, 2020 | 05:08 PM
batman719's Avatar
2019 C43 AMG Coupe
Seeing my logs isn't going to help you. BMS is clearly trying to give you a hand here.
Old Jul 2, 2020 | 06:53 PM
PxcesYT's Avatar
Mercedes C43
No I know that but I just wanna see how your car performs.
