C450/C43 AMG
Wheel spacers and h&r springs
Old Jul 23, 2020 | 07:12 AM
Potochnik11's Avatar
2013 C300
I’m thinking of talking the front wheels out 15mm and the rears 20mm. Are there special 5x112 spacers I need to get? I have a 2017 c43 coupe. Also has anyone with a coupe model put on the h&r lowering springs, also looking into those.
Old Jul 23, 2020 | 10:49 AM
C43HeartBoost's Avatar
C43
I have spacers and H&R springs on my 2017 coupe and could not be happier.
Old Jul 24, 2020 | 07:04 AM
2013 C300
could you send me links to the ones you purchased
Old Jul 24, 2020 | 03:55 PM
C43
I do not have links, as I called my shop and it order the parts for me.
Old Jul 24, 2020 | 09:36 PM
adem_C450's Avatar
C450
H&R 15mm spacers part# 3075725SW
H&R 20mm spacers part# 4075725SW
https://www.ecstuning.com/b-h-and-r-.../3075725sw~hr/
https://www.ecstuning.com/b-h-and-r-.../4075725sw~hr/
This is the setup I have on my C450 sedan as well as the H&R sport springs and it looks perfect.
Front: 15mm Rear: 20mm on stock 18"
Old Jul 25, 2020 | 12:12 AM
C43
Agreed
Old Jul 25, 2020 | 07:48 AM
threeMBs's Avatar
Only MBs - the best or nothing
Above are NOT correct part numbers. They are for BMW and do NOT fit any Mercedes.
The correct part numbers are:
15mm DR 3055665 or 3055665SW(black)
20mm DR 4055665 or 4055665SW(black) or
20mm DRA 40556654 or 40556654SW(black).
Old Jul 25, 2020 | 07:06 PM
Vincent Lluch's Avatar
2019 c43 AMG
Question
how much does the H&R sport spring drop the car? Any issues with scraping on slow bumps, sloped driveways?
Old Jul 25, 2020 | 10:34 PM
adem_C450's Avatar
C450
I believe around 1.2 inches I think. Living in New England is the reason I went with the 18" wheels because of potholes, I have about 2k miles on the setup and I have not had any issues with driveways or parking lot entrances being too steep. I have not scraped on anything yet. All speed-bumps are cleared. The ride is very similar to stock in all modes, but Sport+ is noticeably stiffer in my opinion. To me, the ride height is perfect and any lower it would probably be scraping often, even with all the road work going on, I have not scraped yet. A very practical ride height.
Old Jul 26, 2020 | 11:42 AM
C43
No issues as long as you take bumps and driveways slowly and at an angle.
Old Jul 26, 2020 | 04:14 PM
2013 C300
it says the 20mm will not fit my car. The people on that website said they don’t have any 20mm for my car. Idk if it’ll still fit even though it says it won’t. And I also believe I’ll need extended bolts
Old Jul 26, 2020 | 04:39 PM
threeMBs's Avatar
Ignore "it says" and "people on that website". Spacers will certainly fit the car.
Manufacturer (H&R) says they do, even though H&R's own website sometimes is incomplete:
http://www.hrsprings.com/application...bymake/25/TRAK.
Old Oct 10, 2020 | 02:54 PM
Soobahru's Avatar
C43 cabrio
Agreed
Looks sweet! Any more angles (side, front, rear)? Looks CLEAN!
Old Oct 10, 2020 | 03:15 PM
toosteeley's Avatar
Present: 2019 C43 Estate
H&R wagon springs, stock 19” wheels, wheel stud conversion and 10mm front/15mm rear spacers:
20mm in the rear would definitely fit.
Old Oct 10, 2020 | 05:22 PM
C43
Thanks man. Here are a few more:
Old Oct 10, 2020 | 11:50 PM
pseudoamg's Avatar
C43 AMG
Agreed
Hey bro are those 18 or 19's? I have the stock 19" rims on my 2017 coupe. Just purchased H&R VTF's. What spacers are you running and are you using a KMAC kit?
Old Oct 11, 2020 | 11:48 AM
C43
I do not recall the brand, but they are 12mm up front and 15mm in the rear. I am not using a KMAC kit yet but may do so right before I put a new set of tires on in a few months. I have been lowered for approximately 7000 miles and the tire wear looks relatively normal (unlike some of my previous lowered vehicles).
Old Oct 11, 2020 | 02:49 PM
pseudoamg's Avatar
C43 AMG
​​​​​​KMAC kit or just springs and spacers and did you use the bolts from kit or have to get different ones
Old Oct 11, 2020 | 03:05 PM
pseudoamg's Avatar
C43 AMG
Why when I select these do they say they won't fit? I bought HR VTF springs
Old Oct 11, 2020 | 05:14 PM
pseudoamg's Avatar
C43 AMG
Any idea what part number I'll need for bolts?
Old Oct 11, 2020 | 05:55 PM
toosteeley's Avatar
IMO, rather than having a bunch of different length bolts for front/rear, switching to studs makes it sooo much easier to deal with spacers. Also makes sure they’re perfectly centred to eliminate any chance of vibration.
Old Oct 12, 2020 | 08:24 AM
alexasa's Avatar
c
order spacers via supreme power
Old Dec 4, 2020 | 04:47 PM
FlashA4's Avatar
CLS, SLK, CLK, C, GLC
Hi Toosteeley,
please could you say me, which H&R springs do you have? Adjustable or classic 30 mm front and 30 mm rear?
THX
Old Dec 5, 2020 | 06:47 AM
toosteeley's Avatar
H&R wagon springs. Just the regular non-adjustable ones.
Old Dec 5, 2020 | 07:03 AM
FlashA4's Avatar
and what about the difference between original and this HR?
I’m thinking about to buy them and buy also new rims. The most I want 20”. But in our country is riding on 19” big risk
your wossen are 20”?
