Just installed a Sprintbooster on my 2020 C43
I have looked up several similar products, such as pedal commander, but decided to purchase the Sprint booster instead because the controller is tiny, literally about the size of my thumb. What's nice is that it can remember its current setting and I can disconnect the controller completely (after finding out which mode I like) and store it elsewhere. I find that the drive mode select is enough to change the driving dynamics so I found a setting that I like and disconnected the controller so that I don't have to stick it on the dash or somewhere else in the car, I like a clean look.
There are 2 modes, Sport and Race (and Off), with each mode having the sensitivity ranging from 1 - 9. I set it on Race 6 and it is amazing. I was afraid that it would feel jerky, but not at all. I actually have full control over my throttle and can feather it very lightly if I wanted to, which was actually a huge problem with me on the stock pedal mapping. I used to depress the pedal about an inch without getting much response so then I depressed it a bit more and the car would lunge because all of a sudden the throttle body opens up. I literally had no control between 1-20% of pedal input it seemed like.
This product is very interesting if you look up YoutTube videos on how it actually works. It not only shifts the throttle curve over so that depressing the pedal a small amount results in a larger throttle body opening, it actually SPEEDS UP the opening of the throttle body itself, thus making the response closer to a drive-by-cable system in older cars, which is much, much more direct.
Sure, the Sprintbooster makes it feel like my car has more power now because it remaps the throttle, but that wasn't my reason for getting it. I wanted to get rid of the dead pedal travel and also have more control over my throttle input. To be honest, at $300, it IS pricey since it's not actually doing anything like a tune would, but it improved drive-ability greatly and the extra power really does make the car feel a lot more responsive and faster (yes, the pedal from 80%-100% doesn't add much due to the throttle mapping shifting over).
Just thought I'd post my experience in case anyone is interested in the product or want to get rid of that dead pedal travel without having to pay $2k for a tune. I also did not want to risk voiding my warranty in any way and this was the perfect solution for me. It can be installed in literally 5 minutes and be removed in the same amount of time. I am not affiliated with Sprintbooster in any way.
The latest year for W205 is stated as 2018. I sent an inquiry about later models like my 2021.
