C450/C43 AMG
Coupling flash tunes with JB4
Old Aug 6, 2020 | 07:32 PM
HighSun_Murder's Avatar
C43 AMG / C350 Coupe
Originally Posted by 5ynatra
You're so bent on trying to prove your point by bringing up online posts about said product that has actual proof (video, graphs, dragy, etc) of its performance lmfao, as do other brands.
We get it- you're gonna go with EC 😂
*P.S that same logic you applied right there can be made with almost any brand... it's nothing new
Take a deep breath there buddy, I wouldn't want to have to turn the flame on
I was actually responding to another member who was interested in what I'd heard as it pertains to AMR, I was simply providing information. Maybe give this thread another read, or find another thread to contribute nothing to.
Old Aug 6, 2020 | 07:38 PM
5ynatra's Avatar
'17 C43 AMG [Stage 1+]
That member also happened to be me since I asked, but I was pointing out your crystal clear bias lmfaoo, since your counter-evidence against AMR's was pretty weak to claim "garbage" as a whole, just a bunch of garbage jobs. Cheers for the info though 🍻
Old Aug 7, 2020 | 12:54 PM
speedlimit's Avatar
Administrator Emeritus
Have you ever been or are you now a customer of AMR?
If the answer is yes, please PM me the details of your poor customer service experience. If the answer is no, then kindly stop spreading hear say. Thank you.
Bob
Old Aug 27, 2020 | 12:30 AM
5ynatra's Avatar
Originally Posted by BMS
The BMS is a tuning tool compatible with the factory flash and all aftermarket flash maps. It can do as much or as little as you want.
With aftermarket flash tunes the first step is to log map0 with JB4 disabled, and post it or send it in, so we can see where improvements might be made for your specific application/fuel!
Hey BMS, I got the Jb4 installed on top of the AMR tune, however, when connected via BT on my phone, every gauge on the display works fine except the gear gauge, it stays at 0 and this also reflects in the logs as well. Any way to fix this? I was running a map 1 for a couple runs (to see if there was a difference, and oh boy there was) but I switched back until I get some map 0 logs.
Old Aug 27, 2020 | 09:30 AM
Howyalivin's Avatar
Acura TL-SH, among others
Originally Posted by loungn14
Makes sense. Your best bet would be to ask on the fb group. The forums are pretty much dead
there are (2) 43 groups out there, check the one with the camo car as amr admins that one. Should be able to get you info.
I don't find this forum to be dead. You might get more responses in FB, but I find the level of knowledge is lower in FB as well. Things that have been asked and answered, and are part of settled science here aren't well understood on the FB page.
Old Aug 27, 2020 | 01:28 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
If you email in support you'll get a faster response. IIRC we're still working on the gear gauge, was is showing up before the AMR flash?
-Payam
Old Aug 27, 2020 | 02:49 PM
  #32
5ynatra's Avatar
-Payam
I had the AMR tune in place prior to the installation of JB4, I was just wondering whether if it had to do with a bad installation (all other gauges work) or if it would be a problem if the Gear sensor is always at 0 when doing gear specific boost values
Old Aug 27, 2020 | 04:49 PM
  #33
BMS's Avatar
BMS
2018 C63 Sedan
No problems at all, the gear values are still in development. Sounds like everything is running as it should!
-Payam
Old Sep 16, 2020 | 12:24 PM
  #34
5ynatra's Avatar
Welp, having the stage 1 tune form AMR's COMPORT (93 octane) coupled with the Jb4 (I ran map 2 with specific settings given to me by BMS staff) and WOOOW. (oh and MST intakes)
I have never seen such fast shifts and such a hard 2nd gear pull... I'm rarely even hitting close to 20psi, but I do plan on only switching this on when someone wants the smoke
Using JB4 logs, once of my logs recorded a 3.2 0-60, not going to say that's completely accurate but mid 3s for 0-60 seems like what it's hitting consistently, need to dragy this up soon.
Old Sep 23, 2020 | 12:48 AM
  #35
5ynatra's Avatar
Got the dragy, here's a video of a 0-60 run:
Old Sep 23, 2020 | 05:49 AM
  #36
TWINTURBOS's Avatar
2016 c450
Got the dragy, here's a video of a 0-60 run: https://youtu.be/Nj4xopctf1k
Very nice. Do you have a before and after? Just with the amr tune and than with it coupled with the jb4. Wondering how much difference the jb4 is making.
Old Sep 23, 2020 | 06:11 PM
  #37
5ynatra's Avatar
I'm going to run some on map 0 when conditions are similar to the one I did with map 2 on (temp heat back up again today)
Old Sep 23, 2020 | 06:15 PM
  #38
TWINTURBOS's Avatar
2016 c450
Thanks! Was thinking of picking one up as well if the difference was noticeable.
Old Sep 23, 2020 | 11:48 PM
  #39
5ynatra's Avatar
I went tonight and did some runs. These are with about 75-80% full tank of 93 gas.
JB4 Map 0 + AMR Comport Run 1
JB4 Map 0 + AMR Comport Run 2
JB4 Map 2 + AMR Comport Run 1
JB4 Map 2 + AMR Comport Run 2
Old Sep 24, 2020 | 02:51 PM
  #40
19’43s's Avatar
Mercedes-AMG C43 2019
@DIVINE AMG dawg ion like amr or eurocharged equally I just have my best interests for my car straight the **** up and best interests for all the other 43 owners out here, I was one of the first to even mess w this platform I hope you know that, been here since The jb1 days not even jb4 😂 but got a jb4 once they announced and dropped it for the C43 then ditched the jb4 for a proper tune then went from a 2018 43 to a 2019 43 cause of some bs so I’ve seen both pre face lift and face lift stock and tuned and etc
Old Sep 24, 2020 | 03:14 PM
  #41
5ynatra's Avatar
That's why I opened this thread to see people's experiences with a generic tune and a jb4. When I got the JB4 I didn't just throw it on map 2 and call it day, I emailed BMS with logs containing various settings and they ended up sending me their recommendation and saying that I should be fine running a map 2 with the settings they gave me. Now I'm not saying that that's them saying what I'm doing is great for the motor, but even looking at the logs myself I don't see it hitting over 20 psi at all (with map 2).
Old Sep 24, 2020 | 04:38 PM
  #42
19’43s's Avatar
Jb4 hahahaha
I remember the days when C43TT didn’t have a tune I remember getting a jb4 and it would be better then tunes from amr or anybody really back in 2018 hahaha, I’ve been map 5/6 gang gang e30 demon from time got tired of the performance barriers so I ditched it in 2019 and got a tune after I found out you need a boost controller to get max power out of facelift only w my pre facelift it didn’t need the boost controller attachment
Old Sep 24, 2020 | 05:00 PM
  #43
5ynatra's Avatar
Besides the power boost, I love AMR's burble aspect of their tune and the control/logging of the JB4. being able to also remove ~150 hp relatively quickly is a plus too.
Old Sep 24, 2020 | 10:00 PM
  #44
xX G Xx's Avatar
Tuned '18 C43 coupe & Stock '18 GLE43 coupe
I'm stacking JB4 on top of my generic German tune as well. Also went back and forth with Terry/BMS on which map to use after his review of the logs. Map1 gave me the best results on the available pump gas I have here. (93oct)
Here are my Dragy times:
Tune alone:
1/4: 11.9@117.05mph
100-200km/h: 9.4
Stacking JB4 on Map1:
1/4: 11.6@119.32mph
100-200km/h: 8.9
I daily on Map0.
Old Sep 24, 2020 | 10:02 PM
  #45
19’43s's Avatar
I do 11.5 atm w just a tune on a facelift 19’ no stacking but good not bad for amr or generic tune, impressive just keep it on map 0 check for any inconsistencies in the power band/curve
Old Sep 24, 2020 | 10:27 PM
  #46
5ynatra's Avatar
Originally Posted by 19’43s
I do 11.5 atm w just a tune no stacking but good not bad for amr or generic tune, impressive just keep it on map 0 check for any inconsistencies in the power band/curve
I guess it depends on what kind of tune you actually have. There's a gap in performance between my AMR Comport OTS tune and their rv3.1 tune, which I believe the JB4 fills in regards to the power output, but obviously not the other features that they offer with their rv3.1.
If I had the rv3.1 I definitely wouldn't be looking to move anything past a map 0.
Old Sep 24, 2020 | 11:56 PM
  #47
xX G Xx's Avatar
11.5 with just a tune on a FL is impressive. Can you post your dragy for this particular run?
Old Sep 25, 2020 | 02:27 PM
  #48
19’43s's Avatar
I would love to post my quarter mile but I’d rather do it when I hit the track and get a real drag slip cause dragy sometimes shows 11.49 on good days, good temp but most of the times it’s 11.5. Lemme get better tires and il get 11.4 flat il post the quarter mile slip meanwhile enjoy my dyno numbers
Old Sep 25, 2020 | 02:31 PM
  #49
BMS's Avatar
BMS
2018 C63 Sedan
Tune alone:
1/4: 11.9@117.05mph
100-200km/h: 9.4
1/4: 11.6@119.32mph
100-200km/h: 8.9
I daily on Map0.
Quite a solid improvement!
Old Sep 25, 2020 | 05:02 PM
  #50
Howyalivin's Avatar
Something is amuck with their software. Over 300 ft/lbs. of torque gain? And the dyno graph is whacked. The HP and torque lines should cross at 5252 RPM. A dyno calculates HP by measuring torque, and the formula is HP = torque x RPM / 5252. Because of that constant, HP and torque will intersect at that RPM.
