Yes, another Racechip thread!
Here are a couple videos. It seems like these guys do have the C43 in house and they actually use it when creating a racechip for our C43, which is good to hear. The other video is an installation video. Any feedback welcome. I mainly want a bit more power from my car, the reason I don't want to get an ECU tune is because there is a much higher chance of getting caught, even if it's flashed back to stock. A piggyback seems like I can just remove it, although I am fairly certain that any sort of modifications to values will go through the ECU, which means that ultimately there should be some sort of logs where the dealer can still find out that something was done to this car. However, I find a piggyback tune to be more "invisible" because the tech should not dig this deep into the logs for regular services/maintenance. I'm sure they will if my engine blows up or something, but that's about it.
As for the statement about higher values getting logged in the ECU, that doesn't happen, because to the ECU, all the values were stock. The JB4 essentially lies to the ECU, telling it the boost is lower than what it is for instance, and the ECU increases the boost to what it thinks are stock levels. It never sees out of range values.
There are ways to detect it if you've removed it, but I'm not sure that MB or any other manufacturer goes that far in their software.
The JB4 is different than the above in that it connects to canbus. It allows more performance by accessing more of the car's parameters thus allowing more functions.
Some of the fastest times achieved were either with JB4 stacking with a tune, or JB4 alone.
It's also true that different dynos and even different conditions for runs on the same dyno can yield meaningfully different results.
60-125 mph/100-200 kph runs are a much better test for HP. 1/4 mi runs tend to test "everything" ... driver response, traction, torque and HP.
