Air conditioning temperature
Hi everyone, I think it’s known that a/c on our vehicles is not the strongest, but recently it was 25 degrees Celsius out and the a/c never really felt ice cold. Are there any specs with regards to air temp at the vents that I should be expecting? I feel like taking it in to the dealer will be a waste of my time, but wouldn’t mind verifying the temp myself with a temp gauge.
Thanks!
Thanks!
Received 4,000 Likes
2019 C63CS
Where does this theory come from that an AC needs to feel ice cold? That's uncomfortable to many people, and frankly unhealthy. An AC needs to be able to cool the interior to the set temperature. If it does that, then it works as designed. If it doesn't manage to get the interior to a reasonable set temperature, then it's malfunctioning. I'm not sure why some people think the AC in these cars are weak? Do you want your interior to feel like a fridge? If so, that's not gonna happen.
Don't know what year your car is, but 25C isn't really hot. I was actually out for a canyon run today in my 2019 C63CS (black on black btw). It was 100F (38C) outside, both my front tires were at 180+F (82+C), that shows them red in the instrument cluster. Had the AC set to 68F (20C) and I was comfortable despite working up a "sweat" from ripping through the canyon. I do have the ventilated AMG performance seats, so that keeps my back from sweating, but the AC had no issues keeping the interior comfortable under the burning California sun, and I didn't even have all the vents open, because I don't like being blown at with cold air. I have the outer two of the three center vents closed most of the time, and the passenger side vent is closed as well, because my wife doesn't like it open. I also keep the panoramic roof shade open pretty much all the time, including today. The glass seems very well heat insulated and I like the open air feel.
I don't think there are any specs, but you can measure your interior temp. How cold the air is coming out of the vents is largely irrelevant, as long as the AC manages to maintain the cabin temp at the set temperature.
I also have a c450 and I have to come the same conclusion as you. The a/c in this car is just not that strong...Dont get me wrong, it works and it is sufficient and not defective, but on hotter days (~95°F+ (35°C+)) the air never gets truly cold. It is cool, and it does what it has to do, but when I have the sun baking me through the windshield and the air is just "cool"...that is not a fun time. I'm going to go to the dealer and see if they can give me a shot of refrigerant, hopefully that will do some good. If your a/c isn't that cold at 25°C, I'd say that is a problem.
Sailorlite (07-12-2020)
Thank you for the replies. Yes I don’t feel 25 degrees is that hot but it seems to take 10-15 minutes of driving before the a/c feels cool, and probably 20 mins for the interior to get to the selected temperature. I can’t imagine what it’s like in hotter climates with 30 degree temps. Thank you for the 4 degree target, will see if it gets close to that.
2019 C63CS
jevsays (08-09-2020)
GLA250 4Matic, 911 Carrera S, R1250 GS Adv.
If the air coming into the car through the vents is not refrigerated then the interior will not ever arrive at a cooler temp. It's very possible that your a/c components are not working, which is hopefully still a warranty issue.
As mentioned the incoming air should measure at around 40F.
It's also possible that you're experiencing an electronic "climate control" issue, but without 40F air there's little hope of a comfortable interior temp in hot weather.
Is your refrigerant filled? My AC gets cold within 2 minutes, maybe 4 on a hot summer day (35*C).
The problem for me is that the fans aren't strong enough, I need to turn it on setting 5,6,max for it to start blowing. Everything below it feels similar, if you were to graph the fan speed, it would be very non-linear.
A/c barely works
Hi! I have a problem with my w212, a/c barely works, and diagnostic says there is a problem with communication with sliding sun roof, which my car doesnt even have? Any ideas?
haha this is accurate. you need at 5 and above to get it going. 5 is when the turbo boosters kick in.
My last 3 cars were a CTS-V, Audi s4 and an M5...My c450 has the weakest A/C by a long shot..Pressures on both sides of the compressor are good, its just not as effective as the others were.
Interesting. I test drove a C450 that was sitting out in the hot sun on a 90F day. I immediately noticed the AC wasn't nearly as cold as my W204 C300. Kinda disappointing but not surprising
