Why making things complicated? I can understand the current air quality argument and those who are sensitive might wanna consider replacing the air filter with something that filters out more of the particles that are bothering you. Unfortunately, we don't get the optional air ionization in the USA, which is what would trap those particles. The interior doesn't just heat up from the outside air. It also heats up from the sun entering through the windows etc. The AC in these cars is not an on/off thing. The compressor is variable and it only runs as much as is necessary to maintain the cabin temperature. It's an automatic climate control and the objective of it is to keep the interior temperature at the set temperature. Much like the thermostat in your house. It will run the compressor as much as needed and control the air flow to make sure enough cool or warm air is entering the cabin to reach and maintain the set temperature. You are kidding yourself if you think you can do a better job manually messing with it. BTW, the AC doesn't just cool the interior, but it also removes moisture, that's why letting it run when it rains or during the winter keeps the windows from fogging up. To answer the original question, yes, the recirc automatically turns off after a while. I think it's to make sure the air inside the cabin doesn't get stale, and fresh oxygen is brought in.
