Auto vs Manual mode for fastest 0-60?
I'm not an expert but I believe the E400's (and C400's) actually have a different compression ratio in their engines and are overall designed for less performance. Similarly, the E400 is heavier and likely has different limits applied to the drive train which tunes cannot necessarily overcome.
Also, without launch control, in all of these cars the driver is one of the biggest factors. The fact people with the same tune get wildly different times shows this. So practicing your launch can definitely help.
Your best bet is to find another E400 or see if there are some E400 times posted with specific tunes to make sure yours is running as it should
My 2020 C43 with full tank, first time trying it with JB4 + BCM.
Confident it will go faster with some practice and adjusting of suspension setting and tire pressures.
