C450/C43 AMG
Auto vs Manual mode for fastest 0-60?
Old Aug 30, 2020 | 03:01 AM
TWINTURBOS's Avatar
2016 c450
What do you get the best times with? Am getting 4.8s in humid weather with ~ 2k rmp break boosting in sport+ auto on a currently stock c450.
Old Aug 30, 2020 | 04:07 AM
Trekt43's Avatar
C43
auto 100%
Old Aug 30, 2020 | 10:54 AM
Fresh_Mass's Avatar
C450 AMG
With DME stage 2, red star catless DPs, and BMS intakes, I ran a 4.1 0-60 on my draggy. Car is a C450 auto break boosting to 2 K for launch.
Old Aug 30, 2020 | 04:06 PM
C43HeartBoost's Avatar
C43
Manual, T/C off.
Old Aug 30, 2020 | 04:25 PM
stockbmw's Avatar
2018 C43
Pulling out from gas station other day, car felt so meh on 1 gear manual s+ redlining. Butt dyno feels faster on auto, short changing few hundred rpm.
Old Aug 30, 2020 | 04:33 PM
TWINTURBOS's Avatar
2016 c450
Originally Posted by Trekt43
auto 100%
I'll do some more testing this week to see what I get the best time with.
Old Aug 30, 2020 | 04:34 PM
TWINTURBOS's Avatar
2016 c450
Am getting my tune tomorrow hopefully. Will post results after I've done some testing.
Old Aug 30, 2020 | 04:35 PM
TWINTURBOS's Avatar
2016 c450
Originally Posted by C43HeartBoost
Manual, T/C off.
Thanks, at what rpms are you shifting?
Old Aug 30, 2020 | 05:14 PM
TWINTURBOS's Avatar
2016 c450
Are you planning to have it tuned? I have it scheduled for tomorrow. It feels fairly fast to me stock but there are some great gains to be head with a tune.
Old Aug 30, 2020 | 05:39 PM
Trekt43's Avatar
C43
Huge gains. Personally I think AMG detunes it to help keep the hierarchy with the c63. If they mct’d this car, and launch controlled it, it would be beating c63’s off the line stock (it pretty much already does on non prepped, average launches) simply cause it’s AWD.
The engine is definitely limited by its open deck design and cast rods higher up, but I think AMG could easily have pulled more power out without hitting their warranty thresholds
Old Aug 30, 2020 | 05:58 PM
TWINTURBOS's Avatar
2016 c450
I think you are right. Just like they detuned the w204 c63.
Old Aug 30, 2020 | 07:43 PM
C43
Typo on my part, sorry. I intended on saying auto (old habit). I only use manual for canyons.
Old Aug 31, 2020 | 08:28 AM
AhEmGee's Avatar
2004 E55 K Wagon &. '96 SL500
To get the best times off the lime auto is always faster, as the gearing is so short and the 1-2 shift is easy to mess up due to the slow shifter response.
Old Sep 1, 2020 | 05:55 AM
TWINTURBOS's Avatar
2016 c450
Ah cool, thanks
Old Sep 1, 2020 | 06:01 AM
TWINTURBOS's Avatar
2016 c450
Just got my eurocharged stage 1 and k&n filters and my best time out of 5 was 4.39 break boosting at about 1800 rpm with tc off in 68 degrees (20 celsius) and 85% humidity. What was the weather like for you? I hear it affects performance. Wondering if its worth it now to do the downpipes and intakes.
Old Sep 1, 2020 | 06:15 AM
TWINTURBOS's Avatar
2016 c450
Thanks, those are great times. Are you just running a tune or anything more? Were the times achieved in cool temp?
Just got my eurocharged stage 1 and k&n filters and my best time out of 5 was 4.39 break boosting at about 1800 rpm with tc off in 68 degrees (20 celsius) and 85% humidity. Wondering if I should get downpipes/ intakes.
Old Sep 1, 2020 | 09:29 AM
BenzWay's Avatar
E400 GLE350 C63
This is my E400 2016 same engine as c43 just have the 7g tranny instead of the 9g and a lot heavier. Car is eurocharged Canada v4 stage 2 tuned dp and bmc air filters. Best 0-60 time I got tc off and auto revs to 1.9k
Old Sep 1, 2020 | 10:02 AM
TWINTURBOS's Avatar
2016 c450
Nice, you could probably shave off a bit of time in cold dry weather. Mine is a c450 with the 7 speed as well and this was my best run today after the eurocharge stage 1 tune and filters. Your car is about 300 pounds heavier give or take which makes sense.
Old Sep 1, 2020 | 11:38 AM
BenzWay's Avatar
E400 GLE350 C63
To be quite honest I’m not very impressed by the Eurocharged Canada V4 Tune. So far I’ve raced a 2015 C400 with a kleeman piggyback tune that claims 420hp/430 torque and lost by a car off a dig. Also raced a 2018 C43 dme stage 1 tune claims 460hp and got smoked.
Old Sep 1, 2020 | 11:46 AM
TWINTURBOS's Avatar
2016 c450
Interesting. They do have some quick cars in the leaderboards even in Canada. I might book a dyno timeslot to see how much power the car is putting down.
Old Sep 3, 2020 | 05:16 PM
AhEmGee's Avatar
in 20 degs celcius and high humidiity I can still get 3.65 0-60 all day long and 11.8s 1/4 mile.
Old Sep 3, 2020 | 05:18 PM
AhEmGee's Avatar
i did several roll races vs my friends 2019 standard E63S wagon vs mine, and he barely pulled a full car length by 130mph. Up till then it was a bonnet then half a car ahead.
i had v4 file before & my car was slower on it. Now i have a custom EC map and OPF delete which gained 20-25 whp and tq across the whole rev range.
Old Sep 3, 2020 | 07:10 PM
TWINTURBOS's Avatar
2016 c450
I'm wondering if the 2019s are faster. Also, did eurocharge recommend the opf delete and custom map or was this something you asked for. They didn’t really mention this to me as an option. Thanks though. This is helpful info.
Old Sep 3, 2020 | 07:15 PM
Trekt43's Avatar
C43
You've just compared 3 different cars with 3 different tunes. The engine is only one part of this equation.
I'm not an expert but I believe the E400's (and C400's) actually have a different compression ratio in their engines and are overall designed for less performance. Similarly, the E400 is heavier and likely has different limits applied to the drive train which tunes cannot necessarily overcome.
Also, without launch control, in all of these cars the driver is one of the biggest factors. The fact people with the same tune get wildly different times shows this. So practicing your launch can definitely help.
Your best bet is to find another E400 or see if there are some E400 times posted with specific tunes to make sure yours is running as it should
Old Sep 3, 2020 | 07:28 PM
Trekt43's Avatar
C43
Your car does not have an OPF. OPF's are particulate filters introduced on European cars exhaust I believe MY19 onwards. I don't think it applies to Canadian cars, but regardless it would not be on a 2016. If you want more power you can go stage 2 and get some catless DP's
