Lowered my Michelin Pilot Sport A/S 3+ Tire Pressures
While these tires did marginally improve the car’s ride, I still felt that the suspension was unnecessarily harsh at low speeds. Further, the ride had a low speed coarseness on all but the smoothest of roads. It just made no sense to me that the AMG engineers would have intentionally dialed-in such crude low speed damping characteristics on this car.
After much experimentation and measurements, I have reduced my cold pressures down to 33F and 32R. Just this one change has made a marked improvement in the car’s ride. These are exactly the same pressures Mercedes recommends for the C63S running 19”/20” non run flat tires. (see attached discussion link)
https://mbworld.org/forums/c63-c63s-...-pressure.html
Just relating my experience. YMMV
Nevertheless I'm just going to lower the pressures and see what happens.
I came to this conclusion based on the fact that these tires are closer to the C63’s PS4’s than they are to the factory performance run-flats. A few points to consider:
1) The sidewall heights on the C43 are equal to or greater than those of the 63S.
2) The C63S weighs roughly 100 lbs. more than a C43.
3) I have monitored both tire temperatures and pressure changes and see no issues. Only better.
4) I have also measured tread face temperatures after a mountain run. No issues.
5) I marked my sidewalls and checked for roll-under during hard cornering. No issues.
The car retains its turn-in characteristics but no longer shudders as the front tires move towards understeer during hard cornering
My car is not a daily driver, it was purchased as a winter time backup for our Porsche during cross-country drives. I live on a mountain and have great mountain roads to aggressively drive these cars on. If you are a freeway cruiser, stock pressures work and your MPG will be better.
In the end, the car rides better with no measurable downsides that I can discern.
As I said earlier, YMMV.
