Jb4 c43 running rough / throwing engine lights /low boost
Other than that I would for sure double check your wirings
OP, im guessing you have a faulty wire connection on the JB4, and from the codes I would start with the green fuel pressure plug.
Also, what firmware version are you running?
My guess is it’s being caused by low fuel pressure. Your logs show leaner afr, lower fuel pressure, and higher trims than you want. It could be because of your e85 mix. You’re running a very high mix. Having said that I ran similar mix as you and had some issues, but not the ones you are.
THE OTHER THING is your Fuel OL value is 60 where as mine was 50 and you tmap value is different than mine too. I honestly forget what tmap was for but fuel ol controls the extra amount of fuel requested. For instance setting it to 0 would disable the green wires effect.
long story short im fairly certain you have a fuel problem. Decrease e85 mix (make sure timing stays ok). I’m almost certain you’ll be fine octane wise and probably get improved performance with with a lighter mix. Check with BMS if you should reduce fuel ol to 50 (I forget if this value auto adjust overtime).
if you unplug green wire I’d be really careful about running that thick a mix of e85. Also if you just throwin in 6 gal of e85 and topping up, how much fuel was left from the previous fill? Cause you could still have a couple gallons of e85 left over, now your at 8 gallons in the tank, which is far far far too much.
orher possibilities are inrake leaks, exhaust leaks, bad maf sensors, bad injectors
Edit: (additionally I’d stop doing pulls until it’s sorted. It’s probably “very strong” on some cause you make more power when lean but things get very hot, possibly destructively hot)
