C450/C43 AMG
jb4 green wire
Old Jan 11, 2021 | 02:01 PM
Kevin Diao's Avatar
c450 amg
jb4 green wire
I’m trying to connect the green wire for my jb4 but couldn’t find any guides online, so does anyone know how to install the green wire on the c43/c450 models
Old Jan 13, 2021 | 09:58 PM
BenzWay's Avatar
E400 GLE350 C63
Under the driver side airbox by the fuel rail you’ll see the wire only one will fit the connector so you’ll know
Old Jan 14, 2021 | 02:31 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Check our intake install guide for a photo of the connector.
Old Jan 22, 2021 | 08:51 AM
Kevin Diao's Avatar
c450 amg
octane for map5
thank u i successfully connected the green wire I was also wondering if it’s safe to run 100octane race gas on map 5. If not what mix should I use in order to run map 5. I’m currently hesitant on mixing e85 cause I heard stories where it can be bad for the oem injectors, so I lean toward adding 100 octane fuel instead.
Old Jan 24, 2021 | 01:38 AM
Freder8d's Avatar
2017 AMG C43
For the C43 the injectors are more than enough to blend E85. It's your fuel pump that won't be able to keep up. I have blending E85 with 91 octane (California) for almost a year with no issues. I accidentally found the limit before going into limp mode. With my Eurocharged Tune 4.5gal is the max. I accidentally put in 4.7gal and the check engine light came on. Put more regular gas in and it went away.
Old Jan 25, 2021 | 12:38 PM
BMS's Avatar
BMS
2018 C63 Sedan
Up to 30% E85 has proven to be fine for the platform, but unleaded race gas is great too if you have the cash for it.
