Got into a gasoline fight with my car
I’ve spilled small amounts before on previous cars and never given it second thought besides dumping some water over the affected area.
But this was like a waterfall. Anything to be concerned about?
Filled a spray bottle with Optimum No Rinse and diluted it with water before spraying down the entire affected area at home. It’s like 10 degrees and snowing, so can’t give it a proper wash.
Still smells like gas a little in my garage.
Any thoughts welcomed.
The fuel definitely spilled all inside the gas cap compartment, so I'm guessing that is where the odor is coming from.
Judging by the info. you shared above, with the gas cap closed (obviously), I can just pour some distilled water into the compartment and let it drain through the little hole to the left of the fuel cap?
Also sounds like the paint should be fine? I completely soaked the area twice. Once at the gas station with a large cup of tap water, and once more at home with an entire spray bottle of diluted Optimum No Rinse. No touchless washes in my neck of the woods, so my only option for further protection (given the harsh weather right now), would be to take it to my detailer next week for a clay and a fresh coat of wax.
Much appreciated!
Cheers!
Edit: Although I had already wiped the interior of the fuel compartment with my soapy towel earlier, I poured some distilled water down through the drain and watched it funnel out.
Looked like it was mostly just water. Put about 4 ounces or so through there. Didn't want to go too crazy because it's about to get down to -25 F tonight lol. That plastic in there seems pretty resilient. No signs of any stains or discoloration whatsoever, which is nice.
Unfortunately for me, this seemed to be a malfunctioning pump, as it began leaking gasoline as soon as I unclipped it. Handle wasn’t even depressed.
Bizarre stuff. And still charged me 97 cents for the fuel leaking out 😂
