C450/C43 AMG
Wheel Fitment hitting control arm on C43?
Old Feb 25, 2021 | 02:27 PM
rtjuandi's Avatar
2017 C43 Sedan
I got the Vorsteiner VFF 112s with the specs 19x8.5 et 30 Fronts and 19x9.5 et 46 Rears for my 2017 C43 Sedan, completely stock. I thought that an et 30 would fit after going through many wheel fitment posts. Anybody know whats wrong with these setups or if anybody has the same issue?
Old Feb 25, 2021 | 04:35 PM
toosteeley's Avatar
Present: 2019 C43 Estate
Check the specs stamped on the actual rim. There’s something not right with the rim you’re trying to put on the front. 19x8.5 +30 should not be touching the control arm.
Old Feb 25, 2021 | 10:32 PM
TModelle's Avatar
C190
8.5J ET30 rim edge will not rub the arm unless the rim itself is not up to spec.
Old Feb 25, 2021 | 11:10 PM
jonathan358's Avatar
2018 Mercedes C43 AMG Coupe
Yup, something not right with your wheel. ET30 confirmed fit. Get a refund, if not, spacers...
