C450/C43 AMG
*New* Logos Engineering Motorworks C43/C450 Intercooler
Old Nov 4, 2021 | 06:00 PM
LogosMotorworks's Avatar
Former Vendor of MBWorld
S5,C450
Been available for a bit via direct inquiry, but here it is in full glory. Our Intercooler with charge pipes set. Our kit is competitively priced and available for a discount for those who want to bundle products.
And yes before you mention, its similarly shaped like the "other guy" but the reason is because this is the shape the product takes after maximizing the amount of available space (although we found a extra millimeter here and there)
Please visit our site for more information and specs and for purchase.
https://www.logosengineeringmotorwor...43-intercooler
Features & Performance:
  • The Original small factory intercooler was 3D scanned and reworked & modified to make use of every milimeter
  • Strategic diameters and dimensions chosen to maximize available performance
  • larger core is 138% larger than the factory unit keeping your charge temps nice and cool
  • Extra Beneficial on tuned engines where temperatures can run hotter than stock
  • Charge Pipes are 53mm vs 42 mm of the factory
  • plug and play, perfect fit
  • No tuning required or add the final touch to your build for stage 1 + or stage 2
  • Everything is included to install day 1
  • Fits the C43,GLC43,E400,E43 and others
  • Cooler air with less pressure drop translates into HP and TQ, especially up to redline
  • Denser row and fin core, maximizing performance in the available space
    Construction:
  • Fully Aluminum CNC construction, milled out of a solid block
  • Oversized welds and beefy construction for years of performance
  • Black finish blends into the cars aesthetic for a "stealth" look
  • CNC mounting bracket
  • Premium stainless steel clamps and silicone hoses ensure a easy installation
Old Nov 5, 2021 | 02:10 PM
LBarto's Avatar
Mercedes C43 AMG
    Construction:
good to see this finally releasing - congrats! Does this also accommodate for WMI? Or will there be a revised version down the line to accommodate?
Old Nov 6, 2021 | 12:53 PM
S5,C450
Its right here :-)
Old Nov 25, 2021 | 03:30 PM
Fitis's Avatar
GLC43 AMG Coupe 2020
Ordered mine a minute ago.
Old Mar 11, 2022 | 07:11 AM
LBarto's Avatar
Mercedes C43 AMG
Has anyone had any issues after installing around overboost/underboost codes? Which is limiting power?
We’ve had a look at the installation and everything seems all tightened up correctly (we smoke tested and couldnt see anything). The tuner has also had some issues with trying to get it to run 100% of the time as it just randomly throws the code out?
Old Mar 11, 2022 | 07:42 AM
SilverBullet18's Avatar
C450,GLC 63,VW GTI
What is the code specifically? And what year is your c43?
Old Mar 11, 2022 | 02:26 PM
LBarto's Avatar
Mercedes C43 AMG
there are two codes, they are:
- P023400 - Turbocharger 1 boost pressure too high
- P029900 - Turbocharger 1 boost pressure too low
it happens at random times, and no specific RPM. Like I say we smoke and pressure tested and it seemed fine. So at a bit of a loss as to what could be causing the problems?
do you know if turbocharger 1 is drivers or passenger side? I’m in the UK so RHD (not sure if that makes a difference!)
Old Mar 11, 2022 | 06:36 PM
DirtyDD's Avatar
C43 AMG W205
Clarifying question:
"138% larger than stock"
This means its more than twice the size of the stocker. Do you mean 38% larger than stock? 138% of stock size?
Old Jul 1, 2022 | 09:43 AM
MatthewJ's Avatar
'15 C400 and '15 ML350
Anyone else have this installed? Looking for some feedback as to its performance in the real world.
Old Jul 1, 2022 | 10:42 AM
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
Pardon my ignorance, what is WMI?
Old Jul 1, 2022 | 11:26 AM
MatthewJ's Avatar
Water methanol injection.
Used to supplement fuel and aid in cooling inlet temp.
Old Jul 1, 2022 | 11:51 AM
Well that sounds like envelope-pushing technology! I guess drag racers back in the day would pack their intake in ice, so not a new concept by any means. Thanks.
Old Jul 1, 2022 | 12:51 PM
EbonyCoupe43's Avatar
C43 Coupe
I have 2 m276 cars- my 2 door and a 4 door for the wife/shared car. Both are EC tuned, but I feel like the car with the IC is 'happier" and is more consistent with performance run after run. throttle is a tiny bit snappier and i feel that when i merge on the highway the car is less hesitant and pulls a touch harder as it approaches redline. looking forward to a full blown stage 2 where this IC will do even better. great mod for hotter environments as well. my 2 cents. also real good bang for the buck, quality is excellent.
Old Aug 2, 2022 | 05:50 PM
BoolitSpunjBoon's Avatar
C450 AMG
Can anyone confirm that this will fit a 2016 C450? I know there were differences with the downpipe brackets that caused small Fitment issues. Was wondering if there are any differences that would cause fitment issues regarding the intercooler.
Old Aug 2, 2022 | 09:44 PM
C450,GLC 63,VW GTI
Sold my previous LEM down pipes to a C450 who had the intercooler installed when he went stage 2. He said it went well, bolt on w/ no issues
