C450/C43 AMG
Check Brake Pad Wear
Old Nov 18, 2021 | 04:25 PM
Mozilla's Avatar
C43 AMG coupe 2018
Hi, Today while driving around the city my check brake pad wear light came on. The brakes feel fine, the car only has 21k miles on it. I did a visual inspection and the brake pads seemed to have enough wear left on them. I had just gotten a car wash. Has anyone else seen similar issues ?
Old Nov 19, 2021 | 12:50 AM
SweetAlpaca's Avatar
Mercedes Benz C450 amg
The sensors do come up a little early for the brake pads, but it's to give you time to schedule the maintenance to change them. Can you wait and drive a little bit more? Sure you can, but you have to be cautious about how long and know that in order to be safe, you do need to change them. Also, miles don't matter as much as the way you drive the car. If you're going fast and braking aggressively, your pads will wear off a lot sooner than someone that doesn't drive as aggressively.
Old Nov 19, 2021 | 09:44 AM
RichardCranium3's Avatar
'16 AMG GTS, '21 AMG GLE53
Enough searching here will anecdotally tell you it's likely only the rear pads, specifically the inside pad which you can't see. Rear pads are cheap and a relatively easy job to DIY. My rear pads went out around that timeframe as well.
