Fully disabling driver safety aids for track?
Can all that be turned off completely for autocross and track events? I've read in C63 and GT forums that emergency braking is very difficult to disable, and people put tape over sensors while on-track. Even then, they still experience seat belts tightening unexpectedly. One person received an SOS call on track to make sure the driver was ok. I'll pass on this car if these safety options are always going to be on and make track driving and autocross dangerous. Help, please.
Thanks!
https://mbworld.org/forums/coupe-roa...track-gts.html
Apparently PRE-SAFE is the one that grabs you by the seat belt. I doubt that can be turned off, but you should have your belt pretty tight when on the track anyway!
https://mbworld.org/forums/c450-c43-...d-braking.html
On the latest generation models, the forward collision warning now also turns off if you turn ESP off completely, so it no longer has to be turned off separately. That wasn't the case with the older generation cars, but you may not wanna completely turn off ESP anyway, although in AMGs ESP temporarily reactivates the moment you step on the brakes to help with stabilizing the car in an "oh *****" moment. In my previous Audi RS5 the safety systems turned off with ESP in Sport mode or Off, so that was nice, but in my '19 C63S I have to turn ESP off completely to turn off the safety systems automatically, other than going in and turning them off manually.
The forward collision system definitely intervenes on the track and is annoying. We had to leave it on during the AMG Driving Academy and every time the car in front of me stepped on the brakes my car pretty much automatically started to brake before I wanted to. I had to fall back enough or just let it happen. That's on top of the constant audible alert every time it thought I was approaching the car ahead of me too fast.
Here's another thread on the subject. If it's off you should see it in the instrument cluster. I posted this pic showing at the bottom left that the Active Brake Assist is off with ESP off. The great thing about my '19 C63S is that even with ESP off I can still regulate the traction control in 9 stages like the GT R can (that's what that graphic is), so I still have an adjustable safety net to reduce the risk of spinning out.
https://mbworld.org/forums/coupe-roa...ml#post8332577
