C450/C43 AMG
C43 '17 Software update
Old Mar 8, 2025 | 04:30 PM
  #51
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
the culprit was that throttle body was opening half way only, probably something was missed in the tune file, now i have full boost
Old Mar 8, 2025 | 06:53 PM
  #52
W205C43PFL's Avatar
Glad you finally figured it out.
Old Mar 22, 2025 | 06:13 PM
  #53
ehsan21's Avatar
2017 C43
Did this manage to fix your exhaust note sound ? My car has too stopped popping and banging on the up gear shift.
Old Mar 22, 2025 | 06:16 PM
  #54
actually with half way opened throttle body it had the pops and bangs just initially it wasn't doing it as loud as it was probably because of the adaptation period
verify your car if have any limp code, check on media screen if you see full HP/kW and Nm when you kick down the car, check if you have full boost on the amg screen
this is old video with while i had the boost issue
Old Mar 22, 2025 | 06:33 PM
  #55
ehsan21's Avatar
2017 C43
https://youtube.com/shorts/fDW-lpd_j...trSreClaq-heJk
hmm strange my car has full boost and showing the full 360hp on the screen. I just can’t figure out why my pops and bangs have disappeared. That’s the entire reason I fell in love with the car in the first place ! Is there any other advice you can give me on how I can get this back? Attached is a photo of the software my car is running on the tcu would this have a impact on my cars exhaust note sound?
Old Mar 22, 2025 | 06:39 PM
  #56
I don't think there's a reason because of the TCU the car to start sounds quieter
Maybe you can bring more clarity, does happen from nothing or you did some updates/service?
Old Mar 22, 2025 | 06:50 PM
  #57
ehsan21's Avatar
2017 C43
Bit of a back story: the car I bought was a 2017 c43 that had been in a front end accident. I rebuilt the entire front end of the car but I left out the collision sensor. The symptoms occurred when I went to a coder to have the collision sensor coded out. As far as I’m aware that’s all he did from the ecu. He didn’t perform no updates or resets. Attached is the particular fault that was coded out the car. Since this the car exhaust note has completely changed. I don’t know if this is the main culprit of the exhaust note changing but this is when I noticed the cars behaviour change.
Old Mar 22, 2025 | 06:53 PM
  #58
that;s really strange, do you have power exhaust if so does your flaps are opened on both sides when you press exhaust button or in S+?
previously did you have stage 1 or 2?
Old Mar 22, 2025 | 07:01 PM
  #59
ehsan21's Avatar
2017 C43
I first thought the same. I’d thought it’d be an issue with the flaps but I took the actuator spring out so the flaps stay fully open. This too did not solve the issue and the car did not perform any bangs or pops on the shift.
I can’t 100% say if the car had a remap or not as i personally didn’t remap it and I’ve only owned the car for 2 weeks. I personally think the car was not remapped as a friend of mine has one and his pops and bangs from stock.
Old Mar 22, 2025 | 07:03 PM
  #60
unfortunately i have no other ideas what could be, last thing which is in my mind that the guy my reset your adaptations and you need to drive few hundred km until adapts and you get again pops... give it a try and see how it is
Old Mar 22, 2025 | 07:09 PM
  #61
ehsan21's Avatar
2017 C43
Can an adaptation cause this much of a drastic change the exhaust note ? And can an adaptation be reverted back to its former self ?
Old Mar 22, 2025 | 07:13 PM
  #62
yes at least from what i experienced when dealer remove my stage 2 the car was so quite until did some adaptations and then the car change its sound to better, you can't revert back adaptations but with few hundred km it should make the adaptations back and you should have i hope your bang and pops back )
Old Mar 22, 2025 | 07:35 PM
  #63
W205C43PFL's Avatar
Was the pops and bangs ever present on that car when it was purchased and rebuilt or it never had it since first got it?
Old Mar 22, 2025 | 07:37 PM
  #64
W205C43PFL's Avatar
Yes, certain types of tunes gets rid of the pops and bangs completely.
Old Mar 24, 2025 | 08:53 AM
  #65
MJPfin's Avatar
Any fault codes?
Air leak codes and pops and bangs goes away.
same with cat or O2 codes, some temp codes.
And crappy tunes does it too, just a regular 10% here 20% there tunes will effup the calculations.
Old Mar 24, 2025 | 10:29 AM
  #66
W205C43PFL's Avatar
Originally Posted by MJPfin
Any fault codes?
Good point, worth checking.
Old Mar 24, 2025 | 11:06 AM
  #67
ehsan21's Avatar
2017 C43
Yes, The car sounded amazing! pops, burbles and bangs
Old Mar 24, 2025 | 11:09 AM
  #68
ehsan21's Avatar
2017 C43
Any fault codes?
Not as far as im aware nothing to do with the ECU. The car still has its full power and pulls really well. Is there anyone specific I can go to diagnose this issue?
Old Mar 24, 2025 | 11:21 AM
  #69
ehsan21's Avatar
2017 C43
Any fault codes?
Had an exhaust fault code a few weeks ago for blocked actuator. Fault code cleared and has since not returned. Garage said flaps appear OK…new spark plugs and air filter fitted a few days ago but no software updates done
Old Mar 24, 2025 | 11:24 AM
  #70
W205C43PFL's Avatar
I see.
