C450/C43 AMG
hy.c43 amg 2020 brake pedal problem
Old Apr 7, 2024 | 02:22 AM
Rókajóska's Avatar
c43 amg 2020
2020 amg c 43 I have a brake problem. after starting, the sound of air release is heard. after pressing the pedal, it rarely stops. what could be the problem? can someone help me? thank you
Old Apr 7, 2024 | 07:04 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W205 AMG forum...
Old Dec 23, 2024 | 01:41 PM
longroof5's Avatar
Did you ever get this sorted out? I have the same problem. I've tried replacing the vacuum pump valve that many discuss but it didn't help in my case.
Old Jan 28, 2025 | 08:10 AM
Charlie11's Avatar
2019 AMG C43
I have the same issue. I noticed it started happening around the same time the temperatures began dropping, although that’s probably just a coincidence. The good news is that it doesn’t appear to be negatively impacting the performance of the brakes. That said, I’d still like to figure out what’s causing this.
Old Jan 28, 2025 | 08:26 AM
W205C43PFL's Avatar
Did you also try replacing the vacuum check valve? If so, how is the master cylinder and your brake booster condition?
Old Jan 28, 2025 | 08:53 PM
Charlie11's Avatar
2019 AMG C43
Thanks for the suggestion. I didn’t think to look at the vacuum check valve as the sound was coming from the brake pedal arm in the footwell. I’ll check that, as well as the master cylinder and booster. Though, my car only has 45K km so I would hope these components are still in good shape.
Old Jan 28, 2025 | 08:57 PM
W205C43PFL's Avatar
True, the check valve in particular fails easily, the rest mentioned rarely fails.
