C450/C43 AMG
C450/C43 Front lower control arm (spring link) aftermarket replacement availability
Old Aug 27, 2024 | 07:30 AM
renx's Avatar
C450 wagon
Hello
I am currently searching for a replacement part for my lower control arm. There seems to be play.
OE code seems to be A2053308403 or A205330840364.
The independent shop said that Lemforder/Meyle or other manufacturers’ aftermarket parts do not fit correctly and only OE replacement is safe.
The cost for aftermarket part seems to be ~100 euros, OE about 400 a piece.
Has anyone had more luck with this subject or is OE the only way to go?
Old Apr 28, 2025 | 03:15 AM
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
Originally Posted by renx
Hello
last friday i ordered lemforder too and they don't match properly on the hub when you place it, i guess you end up with oem ones
Old Apr 28, 2025 | 08:09 AM
MatthewJ's Avatar
'15 C400 and '15 ML350
Ive not done LCA's on our platform yet, but the lemforder ones fit well on others.
They should be the manufacture for the OE, What isnt fitting? Maybe FCP or pelican can point you in the right direction for ones that have been tested?
Old Apr 28, 2025 | 08:33 AM
the Lemforder ones are fine for everything that isn't 43 amg, the conus of the LCA is a bit different than the OEM one and that makes the LCA to not fit 100% correct in the bed where the the LCA is going in
that was the reason to not install Lemforder ones and now i have to take OEM which are way more expensive... Lemforder i was able to get 2pcs for 240usd and oem one pcs cost around 440usd
