~85hp loss 2017 c43
I been lurking these forums for a while, its time for my first post. I need help with my car, like the title says I been getting less power in the past month or so.
I first noticed it was a bit slower and thought I was crazy. Decided to run some 0-100km, preciousky my time was close to 4.8 - 5, this time around couldnt get it under 6.92.
I took it to the dealership and the mechanic said it seems like the car is shifting at 5800 instead of recline. He did some software update and was able to get the car to around 270hp when I bought it in it was around 260. The mufflers are removed( I plan on putting them back on) the mechanic at the dealership said "lack of back pressure from no mufflers is probably causing the rest if the powerless so put them back on and if issue persists bring it back".
I find it hard to believe lack if backpressure would have the power that significantly. Any ideas what this could be ?
Currently has 85000km spark plugs were changed at 83k.
I noticed the turbo gauge flutters a lot more and I can't seem to build brake boost. I mentioned this to the dealership and they claim.if anything was wrong with the turbo there would be an engine light so nothing is wrong.
Any help is appreciated!
TL;DR: car shifts at 5800 manual mode or not, hp number float close to 270 but go anywhere near what they used to.
the dealership told me they ran all the codes and nothing came up.
I just changed both parts the other day because my car was doing 0-100 kmh in 5.6 seconds and took a long time to blow up. Also turbo control valve was making these sounds - https://drive.google.com/file/d/1VYr...21or4GL3J/view.
After changing it doing 4.6-4.8 sec to 100 kmh
The turbo control valve part number is A0001531800, check valve just some good one but make sure it's 3mm because I bought 5mm and it was too big.
I just changed both parts the other day because my car was doing 0-100 kmh in 5.6 seconds and took a long time to blow up. Also turbo control valve was making these sounds - drive.google.com/file/d/1VYrj8JGnD1Qj9MUOYc65MiB21or4GL3J/view.
Thanks for chiming in, hopefully that solves OP's issue.
Also on a side note I am now able to build brake boost and the flutters seems to have been corrected with the software updates.
I got a creader elite coming in today hoping to see if any codes comes up.
Omg I think you solved it brother! I don't have the fart noises but there definitely oil coming out of the check valve here's a video https://drive.google.com/file/d/1rAQ...w?usp=drivesdk
How do I differentiate a good check valve from a ba done ? A quick search only shows me valves for like 10-20$ in the video he mentions a volvo valve couldn't seem to find any. Is there a part number ?
Thank you so much for the help!!
Turbo is just a transformer, it transform the exhaust energy into the intake energy. With a loss, of course. So you can monitor the back pressure with any diag system. The value should be higher than intake pressure
I ordered a klifex valve which only get here next week, so in the meantime I got a replacement from amazon and installed it today.
Its making a weird nose when I unplug the vaccum line from it. See video below:
https://drive.google.com/file/d/1s5k...usp=drive_link
Other than I did notice some torque gains and the boost is a lot more consistent not perfect but better. When I pull the vacuum line out the valve is sucking air in. thats the right direction right?
But without, why the gases will choose turbo impeller instead of getting free outside. Imagine a dam for forcing water to spin the turbine from power station
Looks like you have had good help on this already and hope you get it resolved asap!
