Change steering wheel paddle shifters with "Rocket"
I want for quite some time to replace my current shifters with the "rocket" ones ("DOWN" "UP" labels), because my ones are with the "-" "+" label on them (either don't know why is with them, as my one is C43 and not C450 etc.)
Does someone did this change and is it possible to find only the shifter without the switch mechanism (to transfer my switch to rocket shifter), please check image below and do you know what is the part number OR where I can find them?
P.S. I found some "Rocket" ones on ebay but they're with the switch mechanism and the mechanism itself is square not like the one on 2nd picture
My current shifters
Did you went from small shifters to "rocket" ones and if so from where did you order them? thanks
for Mercedes-Benz New Magnetic Paddle shift Complete Magneto-Absorbing T-Carbon Steering Wheel Paddle - AliExpress
this will be your best bet. no need to swap anything over just plug and play
i have a set but im using them to make a mold so they wont be availiable for a couple weeks.
with the housing you posted this set will hook right in. I build custom wheels. Rarely buy parts from eBay anymore as they don’t sell the quantities I buy.
today I found this that looks like OEMs but for my housing type, so im thinking to pull the trigger
https://www.aliexpress.com/item/1005...Cquery_from%3A
