HELP! 2019 C43 Engine not starting but radiator fan turns on at high speed
Somewhere maybe on of the modules isn't communicating, i've checked all the fuses they seem to be okay, and prefuse box (Engine bay) as well to see if there was a break in the fuse (no dice)....i'm running out of options and it almost looks like i'll have to take it in the MB dealership :S (ugh...not ideal)
any help or suggestions to help trouble shoot the unknown issue i am having....
Only take your vehicle to the stealership for recalls. Out of warranty? DIY the work or independent.
If its dead as door nail then its SAM-CGW, but that's working because it still managing chassis power (fan gies to sleep!)
Mercedes plug (OBD DLC) runs off CAN-D a special diagnostic network path.
What does the SCANNER SCREEN SHOWS ???
Do you go through VIN selection then what?
Try using manual VIN selection.
Here it's not only ECU ...
It's the whole CAN-C that's down!
the way to go is unplug CAN-C members until chaos stops.
Then youll know what module is raining on the party.
it could be classic water footwell swamp
(could be Tub-soaked CGW... less likely here)
Could be soaked ISM is a CAN-C VIP!
.... follow evidences.
Here is an example of "NO COM, NO start" : how to question simple results to fix threshold bus plices.
> Report: good + bad:
-- Super useful to see that ECU + TCU + ISM are MIA: kaput !!
-- ESP is still "responding" to scan but has the use of multiple networks to talk...
The bottom line is : you have a real CAN-C issue, it impacts more than ECU alone.
> CAUSE:
-- What's forcing CAN-C to stay down is the question.
This can be simple with no expensive blind-shots.
-- Right now the WHOLE CAN-C string of modules is missing.... as in it must be shorted. How do these chassis routinely deliver that (swamped) ?
-- I do NOT think power supply is missing from F-SAM.
> TROUBLESHOOTING:
Disconnect your non-stop fan to preserve battery power while engine is off (Do reconnect it with engine running...)
-- 1 > Disconnect ECU out of circuit.
Rescan without ECU connected.
Are TCU + ISM alive now ??
-- 2 > Go look at your CAN BUS-BARS for water crusties signs.
Carpeting at front doors thresholds on both sides.
Be sure to carefully tag each individual wire position then disconnect them until bus comes back alive, hopefully. (each has an individual slot that identify what connector it is - Not random.)
At that point you should know what single module is collapsing your CAN-C Bus.
thanks a million for the direction! Can you tell me where can-c is? I did pull the carpet on both the front and passenger side didn’t see any water residue or swamps in those areas.
I did do another rescan and individually tested using launch and I would say the majority had the “combustion engine” code which probably means the engine is on… most of them cleared away
hi w205c43pfl yes I’m just outside Toronto in GTA I’ll definitely look them up thanks for info!
If you don't have Mercedes WIS access, buy a quick-cheap subscription to "ALLDATA DIY" to gain on-line access in 5mn without any delay.
Using that diagram you can know which bus-bar module you're pulling to isolate the troublemaker keep your CAN-C bus down with a short.
Now let's recap...
You dont have "carpet swamp"
your threshokds liok clean/dry
you dont have swamped F-SAM its working
but CAN-C is still down....
LOCATE **ISM** bus-bar slot: Unplug it !!!
then scan to see if CAN-C responds.
I am in the Ottawa area but currently out of country.
it is what it is. https://mbworld.org/forums/new-membe...-mb-world.html
@CaliBenzDriver and @W205C43PFL thanks for all your help and guidance throughout this whole ordeal the car is up and running now!
How to keep Pkg Module from getting unstable or what was causing this ??
Now that the emergency is passed you have time to prevent next installment when you least expect it.
It would seem your chassis may benefit from REBOOT therapy.
I took it Mercedes Dealership who my good friend works a tech. He was well aware ahead of time and tried guiding me through the process of identifying where the issue was. I went through the whole hassle of getting it towed, and when he began working on the car…it started no problem. He even went ran it through Xentry and only one code came up faulty which was the parking module…cleared the code and bang no issues. He told me if that happened again just unplug the parking module at the back trunk in the driver seat….funny it was it had a mind of its own
Also rear radar modules (inside bumper corners ) have been shown to disable engine start.
Screen Shot #1 (codes after the initial DTC clear)
Screen Shot #2 (after my friend tested the car he figure he put it in Xentry and this code came up on the first visit):
Screenshot #3 Car started and engine on - this is after the tow put the car on the ground. (Sorry for some reason this forum won't accept my video clips) and what the dashboard showed while the engine was running - the only thing was that yellow parking lamp stayed on constant and the red parking lamp was blinking....normally it wouldn't blink in normal driving conditions.
Screenshot #4 Car turned off after the car started - screenshot of the dashboard red parking lamp still blinking:
Screenshot # 5 Car wont start and this screenshot shows the dashboard with the car in the "ON" #2 position
im puzzled? but shared that whole process with my friend to replicate the issue by using a tow machine (since the car cant go into neutral)
Any ideas @CaliBenzDriver ?
Back to square one: CAN-C gets disabled by a member module.
This time we know it's an unstable module a reboot may help.
> From your CAN-C bus-bar at foir threshold :
-- unplug the ESP module then scan chassis.
-- repeat with ISM then scan again...
> what do you see?
