C450/C43 AMG
Diff & Transfer Case Fluid Reco
Old Dec 11, 2025 | 10:24 AM
GWSHARK's Avatar
2017 C43 Sedan
Hi All, About to do fluids on my 2017 with 148k. Was going to use Motul Diff and transfer case fluids wondering if anyone has any experience ( negative) with these choices vs MB fluids. Appreciate any insight you can share.
Old Dec 14, 2025 | 08:40 AM
Evolove's Avatar
2018 c43
I was also thinking of going full motul for diffs and transmission. For the transfer case i think its lubricated via transmission, but im not 100% sure.
Old Dec 14, 2025 | 08:47 AM
W205C43PFL's Avatar
Thought it was as well until realized they changed it for the 9G. It is now separate.
Old Dec 21, 2025 | 04:18 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Automatic transmissions are super-picky on the ATF viscosity: use only matching genuine MB or OE - Not "compatibles" ATF !!
Everywhere else better lubricants are welcomed of course with shorter intervals too and magnetic drain plugs to catch steel glitter.
Old Jan 7, 2026 | 12:28 PM
Banil's Avatar
C43 AMG W205
Som of pepole say that in back diff you need put oem mb fluid but i just putted mobilo1 and even -20 no noises from reductors just remember front diff fren!
Old Jan 11, 2026 | 08:39 PM
TwoC400s's Avatar
2015 C400 4MATIC Palladium Silver Metallic
I've been using Ravenol TDG in the front and rear diffs in both my cars for about 3 years, zero complaints.
Old Jan 23, 2026 | 01:47 PM
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
Hi. The next time you replace fluid in your front diff, could you take pics or a video of where the fill and drain plugs are? My dealership service guy said there's no service interval for the front diff and he's not sure if it even has drain/fill plugs. Sounds like you can put this issue to rest for me! Thanks.
Old Jan 23, 2026 | 05:24 PM
W205C43PFL's Avatar
not op but yes there is no service interval for the front diff same goes with transfer case but it is nothing close to lifetime fluid and does still get worn out as the car gains mileage so should change it.
Old Jan 23, 2026 | 06:49 PM
do not snooze...
There are a lot of standard repairs that don't have a related maintenance...
You must replace the fluid before input-bearings fall apart destroying differential.
No service guarantees complete overhaul repair or reman. swap.
Old Jan 24, 2026 | 12:24 PM
TwoC400s's Avatar
One thing to note, I have a 7 speed transmission, so my transfer case fluid is shared with the transmission fluid. Unlike the 9 speed cars.
There's no fill plug on the front diff, I used the fill adapter for the trans (CTA tool) they have the same thread and pump 1.1L up into the diff and then try to get the plug threaded back up before I loose too much.
Old Jan 25, 2026 | 02:12 PM
////AMG_C43's Avatar
2019 C43
Last week I completed fluid changes on both differentials and the transfer case on my 2019 facelift with the 9-speed transmission.
The front differential on my car has both a drain plug and a fill plug. If my memory serves me correctly, they were both 8mm hex plugs. Both are located on the passenger’s side of the case.
The transfer case has only a drain plug. In order to drain the transfer case, you must remove the drain plug (6mm), back out an oil control screw (T30), and then pick/pull out a plastic stand tube in order to get a full drain. After draining, you then replace the stand tube and fill from the bottom. You then overfill and allow the excess to drain-off to the top of the stand tube. The lubricant is MB 236.15 spec ATF (blue) and not the same as that used in either the 7 or 9 speed transmissions. I have attached a photo of the plastic stand tube along with a useful video I found on YouTube.
Hope this helps.
Old Jan 25, 2026 | 03:00 PM
W205C43PFL's Avatar
Hope this helps.
https://www.youtube.com/watch?v=28TU...vV6f&index=298
Old Jan 25, 2026 | 07:22 PM
@////AMG_C43 I don't know if I trust myself to get that tube out without damaging it - no fancy dealership wire hook tool. Would a simple bent pick tool work? Any trick to putting the tube back into the proper position, like proper rotation? I don't have a fluid dispenser like that. What is it technically called so I can look for one for sale?
The front diff should be simple!
Thanks for the info!
Old Jan 26, 2026 | 11:03 AM
atomek's Avatar
2020 AMG C 43
I'll add my two cents here as I recently did a a transfer case fluid change.
Used MB blue fluid on my 2020 c43 9-speed (yours might differ)
Picked up this pick tool on
amazon amazon
Picked up the pipe replacement from MB Dealer (again this is for my 2020 c43 but it might be the same). I think it came with a new screw and washer.
Measure how much comes out. New tube back in. Screw in the bolt so the new pipe clicks in. Unbolt. Used a suction pump to pump back in the fluid. Over fill it just a tad bit more so it can drain out a bit. Once steady stream gets a break in the flow. Add the bolt back in and torque down.
Old Feb 16, 2026 | 04:23 AM
thereabennyhill's Avatar
W164
Agreed. My front diff started to make noises and whirr at 130k km, and when I changed the fluid it came out black. I replaced fluid in the rear at same time, and the rear fluid was as good as new fluid.
I purchased a second hand front diff and plan to swap at a time in the best future, but the new oil has made the noise in the front diff almost disappear for past 5k km
Old Feb 20, 2026 | 02:33 PM
C63s_Jack's Avatar
AMG C63s Coupe
Are you sure ?
check out https://operatingfluids.mercedes-benz.com
Old Feb 24, 2026 | 05:20 PM
2019 C43
Originally Posted by C63s_Jack
My reference to the MB236.15 was specific to the transfer case. I verified that this was the correct lubricant when I purchased at the dealer.
Old Feb 24, 2026 | 05:43 PM
DIFF NO ATF
Lets keep it clear that axle differentials do not run on blue ATF like Tranny/Xfer case.
