Rear Differential humming noise
I bought it into a local repair shop -- not Mercedes specialized, just normal automotive shop.
They put a stethoscope on it and said noise was coming from the rear Diff. I paid them to replace the rear differential fluid, with no change. They said the fluid did not have any metal flakes in it.
I took to to the MB dealer where I purchase the car. They did indeed confirm the noise along with some others issues -- which I will post a separate thread on. Here is the video diagnostic: https://drive.google.com/file/d/1EBI...ew?usp=sharing (55 second mark)
Car is about 10 years old and 62K miles on it -- I don't track it or race it at all. After first set of tires that were so expensive, I stopped pushing the car. I drive it casually 16 miles a day round trip for work.
Some questions:
1) Is this typical for this mileage, I didn't find a lot of instances of this on this forum and Grok said it is not typical
2) Dealer quoted $7,800 for replacement. A transmission specialist quoted $4,300 for it with MB ordered part. I'm assuming that $3,500 difference is worth going to a transmission specialist even if they are not MB specialist? They said a transmission is a transmission.
Thanks for the thoughts!
It's a simple job for pros with 4 new bearings pressed in.
Use a $30 neodymium drain plug to capture glittery contaminants to stop repeat...
