Slipping trans 3rd to 4th gear
It occasionally slip when the car shifts from 3rd to 4th gear. It increases the rpm by itself, then shifts to 4th gear. It only happens with lighter throttle.
It was already doing this before the oil change.
The oil is original Mercedes, the oil pan is aftermarket, the oil level is correct - done with xentry
After 1,500 miles, an adaptation was done, the adaptation values were fine, but it still does it now.
Will it be mechatronics bad? Xentry diagnostics is clean, no codes
https://youtube.com/shorts/WCFfpzdEHXc
You've got to troubleshoot this without open box out of car:
Read live pressure data from TCU.
Don't expect Xentry to print out fault codes.
Any shop is going to get your wallet wide open with this... any warranty of results??
> No mystery...
The current condition is based on how car was used for how long.
Lighter throttle means less pressure.
Hot frictions damage seals that drop clutch pressure that keep clutch packs loose.
Are 3-4 adaptations failing ?
What's the current blue-book value??
