C450/C43 AMG
Tire Replacement Question
Old May 18, 2026 | 11:57 AM
imj0257's Avatar
C450 AMG
Is replacing only 2 tires (same axle?) Ok?
Unsurprisingly, my C450's front tires are very worn and need to be replaced, but the rears have plenty of tread left. Is it ok to replace only the front tires (would be same exact tire)? I keep reading different opinions. Some say you shouldn't because it could put stress on the differential and jack some mechanical things up. But some people say it is ok as long as you replace both fronts.
Was this ever answered?
Old May 18, 2026 | 01:35 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
I vote keep each axle with similar wear on tires for no problems, based on what i have read. This is obviously not an expert opinion.
Old May 18, 2026 | 03:01 PM
user33's Avatar
Originally Posted by imj0257
Is replacing only 2 tires (same axle?) Ok? ...
OK to do.
Old May 19, 2026 | 07:08 PM
dpollack's Avatar
2021 AMG C43
I'd say yes. Looking to buy mine I looked at a bunch of Carfax tires front, tires rear, breaks every 20,000 miles it was one or the other. My fronts were shot so I took off the run-flats and got Michelin Polit Sports 4 S. $1400.00 all in at Sams Club. So much smoother and will last longer, I hope. I have a flat repair kit and a tiny compressor. Sold the used rears on Facebook for $150.00. DP
Old May 19, 2026 | 07:20 PM
superswiss's Avatar
2019 C63CS
Strictly speaking it depends on the tread wear difference between any two tires. The general guidance for 4Matic and pretty much any AWD system is that the tread wear difference between any two tires should not exceed 2/32" to 3/32". Given that a new tire typically has about 10/32" of tread, it's ok to just replace the front tires if the rears still have 7/32" to 8/32" of tread.
