C450/C43 AMG
Rapid ticking in line with throttle C43.
Old Feb 7, 2026 | 05:12 AM
SpizzleKicks's Avatar
C43
Can hear a rapid ticking when engines on at idle that speeds up in line with the throttle as opposed to revs.
Cant really hear from outside only in the cabin.
Not a knocking very much a tick.
Too quiet for video unfortunately.
2018 C43.
Any ideas?
Cheers!
Old Feb 7, 2026 | 12:27 PM
GermanCarShow's Avatar
2017 C43, 1966 230SL, 2006 Jeep Rubicon
Originally Posted by SpizzleKicks
... at idle that speeds up in line with the throttle as opposed to revs.
Please help us understand the difference between throttle and rev changes. Don't the revs always increase with throttle input?
Old Feb 7, 2026 | 02:15 PM
C43
haha yes, does sound ridiculous apologies.
So when the car shifts down a gear the ticking doesnt shoot up in speed as the revs go up, its more linked to accelerator input.
Old Feb 7, 2026 | 03:29 PM
C43
On further inspection they do get faster as revs climb but even say i hold a gear in manual and the revs maintain but i take foot totally off the gas the ticks die off.
Old Feb 8, 2026 | 05:06 AM
C43
Video attached!
File Type: mov
Old Feb 8, 2026 | 05:07 AM
C43
Oil levels fine.
Old Feb 8, 2026 | 12:37 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
clear idle rattle
Video attached!
Sounds like loose turbos waste gates rattling...
What is your mileage ?
Old Feb 8, 2026 | 12:42 PM
W205C43PFL's Avatar
2018 C43.
Any ideas?
Cheers!
Video attached!
This? https://mbworld.org/forums/e-class-w...st-4k-rpm.html
Old Feb 8, 2026 | 12:49 PM
C43
54k miles.
Boost is always fine, no limp mode, no codes. Car had turbo solenoid replaced as it had the “farting” noise. Thats now gone.
Old Apr 15, 2026 | 03:44 PM
W205C43PFL's Avatar
54k miles.
Did you have it fixed OP, hopefully you did.
Old Apr 16, 2026 | 01:40 PM
C43
Dont really no what to fix as its not showing any faults anywhere. Not got any worse or better.
Old Apr 16, 2026 | 06:10 PM
W205C43PFL's Avatar
First I thought it might be something rattling under the hood, since you mentioned you can only hear it inside the cabin, do we suspect something rattling from the dash?
Old Apr 16, 2026 | 06:12 PM
W205C43PFL's Avatar
The sound might also be coming from the engine bay entering the cabin air filter and through the vents. Since the cabin is insulated, that might explain why the sound is more prominent.
Old Apr 17, 2026 | 02:05 AM
C43
its definitely engine bay (in front of the driver side) but close to the bulk head which is why i can hear it in the cab.
It disappears after a long drive, really strange one to be honest. I dont think its something loose, its not connected to heating of fans etc as ive turned all those off and still there.
Cant seem to figure it out.
After re watching the video its alot more prominent in the video than real life, the phone mic has done an incredible job of isolating it above the engine noise, as its not so discernible as that to the ear.
Old Apr 17, 2026 | 07:28 AM
W205C43PFL's Avatar
Does it sound like crickets to you? You might want to check the condition of the belts.
Old Apr 17, 2026 | 07:54 AM
PotatoHeadII's Avatar
2018 C43.
Any ideas?
Cheers!
Is this new or you just noticed it. The injectors can be noisy, as well as the HPFP. Try to isolate the noise. On one side of the engine or both? Back or front. The HPFP is located on the back of the engine on Bank 1 (right side).
Old Apr 17, 2026 | 07:58 AM
OK, just read that other posts. By “driver’s side”, which side do you mean. We don’t know where you are from or if you live in a country that has everything backwards.
Old Apr 17, 2026 | 08:02 AM
C43
its 100% back of engine by the bulk head, drivers side (UK so RHS)
Old Apr 17, 2026 | 08:03 AM
C43
Can you see the video?
Old Apr 17, 2026 | 09:41 AM
W205C43PFL's Avatar
Thanks for chiming in, this is the video OP posted. https://mbworld.org/forums/attachmen...3-img_3086.mov it does seem way louder than I expect for this car will need to check my car next week but even if my car does it like OP, it might still not be normal. So not really a control vs test situation. Going to call in another C 43 forum member @KristiyanPetrov and compare that way.
I just don't recall hearing these sounds like OP. If what I am hearing in OP's video is what I am thinking ie. Cricket noises, it might be from the belts perhaps ie. https://mbworld.org/forums/c450-c43-...leys-pita.html
Old Apr 17, 2026 | 09:48 AM
W205C43PFL's Avatar
So I rewatched the video on a different device, I hear the normal injector ticking but I am also hearing a cricket noise that I do not believe is present on my car. Is that what you are referring to OP?
Old Apr 17, 2026 | 09:50 AM
C43
Thanks for the replies!
as i mentioned the video has REALLY isolated the sound on the mic. It absolutely isnt that loud in real life, the engine noise is louder and mostly drowns it out.
Not sure that helps, but its not as severe as it sounds, although its great to help hear the noise i am concerned about.
Old Apr 17, 2026 | 09:53 AM
W205C43PFL's Avatar
So does it sound like cricket?
Old Apr 17, 2026 | 10:05 AM
C43
yeah. Its the noise you hear on the video. But as i say its not as loud as it sounds in the video. The sound you hear though is the noise im concerned about
Old Apr 17, 2026 | 10:34 AM
W205C43PFL's Avatar
I will need to check my car next week, what is the condition of all your belts?
We already have all the M276 experts here including but not limited to @CaliBenzDriver Although we are missing @S-Prihadi , let me Ring him up.
