2008 C63
1 Post
W220 M113K
2008 C63
http://www.edmunds.com/insideline/do...cleId=116250#4
The deep front air dam and big air intakes on this 2008 Mercedes-Benz C-Class are sure signs there's no ordinary V6 under the hood. This is a test mule of the high-performance 2008 Mercedes-Benz C63 AMG. Caught testing on Germany's infamous Nürburgring, it's Mercedes' answer to the 2007 Audi RS4, which is already on sale, and the V8-powered 2008 BMW M3, which is still in the hopper.
Mercedes has been stuffing its new 507-horsepower 6.2-liter V8 into everything. We've already seen the CLK63, the E63, the S63, the CLS63, the R63 and the ML63. Now the smallest sedan in the company's lineup will get the 6,208cc four-valve DOHC V8. Official output is 507 hp at 6,800 rpm and 465 pound-feet of torque at 5,200 rpm in most applications, but in the CLK63 and the C63 the new V8 produces 475 hp at 6,800 rpm, and 465 lb-ft of torque at 5,000 rpm, which is a 30-percent and 24-percent increase over the 2006 C55's 5.4-liter output.
That power will be sent to the C63's rear wheels with the company's now ubiquitous 7-speed automatic transmission. This prototype wears a set of mismatched 18-inch wheels, which are no doubt bolted to the same fade-resistant composite-construction front brake discs we sampled on the 2007 CLK63.
Even with those mismatched wheels and massive amounts of camouflage, we already like the way this new C-Class looks. Up front it's clear the 2008 C-Class will adopt the styling of the 2007 S-Class by tossing its oval headlights in favor of more rectangular-shaped housings. The grille stretches wider across the front with a narrower, lower air intake than the current model. More prominent side mirrors are also an obvious change. In back, the production taillights will also have a shape similar to the S-Class, and those quad pipes are hard to miss.
Look for the 2008 Mercedes-Benz C-Class to make its debut at the Paris auto show in September with U.S. sales starting next spring. The C63 won't be far behind.
1 Post
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
TO confirm what is being stated, I am currently in Stuggart and just came back from a plant tour of AMG Affalterbach. During the tour I noticed the production charts they posted on the bulletin boards and started reading down the line of the enginings currently being produced. ML63 - CLS 63 - E63 - S63 - and then i stumble upon C63. ITs coming... I just dont know when...
07 SL550; C32 (sold)
Originally Posted by MiamiE55
475hp/465 lb-ft !
That thing should be blazing..
Porsche Cayenne Turbo
I just LOVE the HP War that Mercedes has started with BMW and Audi.
just the mention of a 6.3 V8 in a C Class 5 years ago and people would think you were nuts
2006 BMW X5 4.8is and 2005 C55 AMG
Originally Posted by amgme
what if it outperforms the higher class models...
