C63 Amg Released
Tuning the S65 engine is a special case. It's not that software changes on a turbocharged car are particularly effective; it's that the S/SL/CL65 ECU contains a torque limiter to protect the transmission. It limits boost in the midrange. All the tuners need to do is disable it and they have another 100 ft-lbs. The stock ECU also has a conservative redline. Raise that as well and 100 HP is easy, especially if you optimize the maps for better fuel. This is not a typical situation for a tuner with either a normally aspirated or forced induction engine.
Forced induction will be the next step, however 11.3:1 CR limits boost on street gas to 3-4 psi at best.
I am getting baselines on client's E63 next week.....
Why is that? How is it something so vile as the new M3 (IMHO) gets so much press, when the better looking, and probably better performing C63 gets less? Makes no sense.
I assume it has to do with the M3 being historically, the better car. But given what we know now, I think this will be the first time the C Class might actually out-class and out-gun the BMW......
The AMG has the BMW on looks, with light mods the AMG can easily out-gun, out-drag, and out-perform the BMW, the AMG has the better interior, etc, etc.
The only saving grace the M3 has is it's legendary handling......and I'm betting there's even a solution to beat that problem.......
NASCRAP? Are you kidding me? Ever heard of the German DTM?
really ?
Like it or not, the C63 (like the RS4) are always in "follow" mode rather than "lead" mode when it comes to all-out performance sedans. It would take a major, long-term flop by BMW to change this.
But we shall see
Cant wait
AMG should be able to provide the program to get the most of these engines. Unfotunately, it's tougher to get it unless you're in Germany or if you have connections. It doesn't matter. Renntech, Kleemann, etc. should have chip programs available.
Here is what the c55 gain was just from a chip.
In standard form, the C55 AMG 5.5 V8 produces 362 hp and 376 lb.-ft.
Powerchip increase it's power to between 380 hp it's torque to between 394 lb.-ft
The price of the Powerchip is USD $990.00.
Thats 18 hp with 91 octane. If this follows true to the c63 the car is easy to get to 475. So some where they can squeez out 25 more hp I would guess.
457 HP
6,2-liter V8
100 km/u in 4.5 sec.
600 Nm @ 6.000 rpm
250 km/h topspeed
"Mercedes has taken the wraps of the ultimate version of its all-new C-Class sedan - the C63 AMG with 457 hp and 443 pound-feet of torque.
Under the hood is the same 6.3-litre V-8 that's in AMG versions of the M-Class and CL. In the C-Class it gives a 0-60 mph time of 4.5 seconds and an electronically limited top speed of 155 mph.
Mated to the engine is AMG's Speedshift Plus 7G-TRONIC transmission. Steering wheel shift paddles and three driving modes - Sport, Comfort and Manual - are standard. The newcomer will be the first AMG car to feature an automatic throttle-blipping function during downshifts. Mercedes say this enhances the driver's emotional experience, but also gives almost completely jolt-free downshifting.
It's also the first AMG to feature a three-stage stability control system, which allows the driver to pre-set the vehicle's dynamic thresholds. Put simply, this means he can predetermine at which point during an extreme maneuver he or she wants the stability control to activate.
A sports suspension and 18-inch AMG alloys (or optional 19-inch rims) will offer an outstanding driving experience, according to the German firm."
http://www.thecarconnection.com/Vehi...84.A12548.html
source: Beckhamania (automanias.nl)
That's one FINE LOOKING car.. PERIOD!!
