E63 vs the C63
http://www.caranddriver.com/assets/d..._cabrio_ts.pdf
Ok...the links are both Car & Driver test summary sheets that they have on their websites for the E63 and CLK63 (the cabriolet...not the Black Series).
The E63 weighs in at over 4,300lbs and the CLK63 comes in at a little over 4,100lbs. The CLK63 reported pumps out 32hp less at 475hp, with the same torque rating as the E63. You will notice that the CLK63 pretty much walks away from the E63 above 60mph. The E63 was even tested in cooler weather (18 degrees cooler) than the CLK63. It should also be noted that the Black Series CLK63 didn't really test much better than this Cabriolet.
The C63 reportedly weighs in at only 3,800lbs (we'll see) and pumps out 450hp/443lb-ft of torque. The 25hp (22lbs-ft torque) deficit to the CLK63 isn't much when you are talking about pushing 300lbs fewer. The C63's 57hp/22lb-ft of torque are not as significant when looking at the 500lbs differential. The C63's relative torque advantage is further bolstered by the apparent use of the 2.82 gearing from the Black Series (versus the 2.65 gearing employed by the CLK63 and E63). When you factor all this, you will have a car capable of 4.2-4.3 0-60 times and one capable of sub-10 second runs to 100mph and mid-12's in the 1/4 mile.
Tom
Last edited by charl1exbr0wn; Sep 14, 2007 at 12:04 PM. Reason: grammatical errors
Tom
If you read a recent article on this board about the C63, product engineer clearly states that the C63 has small air boxes and a different ECU map.
Getting this car back to 500+hp will not a problem.
Reducing weight on a E or CLS is a problem.
But looks like E-class sales are closing the gap and it actually outsold W203 last year. It'll be interesting to see the numbers for next year with the new W204 in the picture.
I have a Audi S4 and I'm looking to trade it in for an AMG but I want something different than what my Dad has but I want to be just as fast if not faster! Also, I have a friend that has a bmw M5 and a neighbor that has a audi RS4 so obviously I want to be faster than both of them.
Is the new C63 the way to go and keep up with the "Jones" and not be in the $90K price range? Is it faster than the E63, M5 or RS4? Should I go and get my name on the waiting list at Mercedes?
Just look at C&D test of a CLK63 Convertible, which is heavier than C63. It did 0-60 in 4.2 seconds and 1/4 mile at 12.5 @ 116mph in their test, while E63 was slower and did 12.6 @ 115mph in their test. Because C63 is lighter than CLK63 Convertible, you can assume its faster or at least just as fast.
Finally, C55 was a mid 13 second car, while E55 was a mid 12 second car. You paid more for E55 and you got a huge performance advantage, which is how it should be. With C63 and E63, Mercedes made them both mid 12 second cars with C63 having advantage due to it being lighter. Why Mercedes would upgrade C class's performance and keep the E class's performance the same (or less) is beyond me
. And here I thought the Orange County was all about spoiled rich kids living the "image".Here's the way I see it. Dad worked hard to earn his E63. So did the neighbors. Before you feel the need to be better than Dad, try out-working him to earn your own E or C or whatever you want. And, it is not "obvious" why you have to be faster than Dad (when he is paying for the car in the first place) or the neighbors/friends.
Hopefully, by the time you earn it, you will have matured to the point you don't suffer from odd form of P-nis envy.
Las Vegas is pretty bad, all the new money made in the real estate. Mix that with the gambling and I'd say that some people there are worse than some in Orange County.
Tom
Thanks for posting this..
The temperature was not as much as a factor in testing as was the drop in barometric pressure. This may really have skewed the comparison. I find it BEYOND BELIEF that Density Air calculations are not done and listed during such tests.
The E63 was run at a 1300 ft disadvantage due to the severly low barometric pressure.
Doing an SAE correction for the acceleration the E63 is .2 faster than the CLK 63. This puts both cars at sea level or a barometer of 29.92.
E63 is faster and tuning the 63 engine is much more difficult than the 55 engine it replaced. The 63 is proving to be a huge tuner challenge.
engine is the same, but it is detuned, and it will cost some serious coin to bring it up to 514 bhp. Same prob we are having getting the current 63's to 525-550. Tuners have had 12 months and still we have not seen one 63 dyno at more than 440 to the wheel. why? The ECU tune(software) has accomplished very very minimal gains if any at all. Nobody has the map, the ecu map that will easily accomplish 50 hp?
The E63 has 507 horsepower at 465 ft lb torque.
Sure the E class may weigh more but according to some stats I read, the E has a slightly better weight to power distribution ratio than the lighter more nimble C.
The C63 weighs 3650 lbs curb. The E63 is at around 4100 lbs curb.
My bet is still on the E. And why would Mercedes make the cheaper lower class of competition C faster than the higher E?
That is how it is possible for the "lowly C" to be faster than E.....TEMPORARILY.
C class AMG, because that would make you a pathetic little fool with identity issues who seeks status through material objects rather than looking for the ideal driving experience. If status was the main ridiculous reason you chose the E class AMG then I particularly sorry for you because you spent $30,000 more for a larger uglier car than the new C63 which is subjectively the same speed or slower with the exact same engine. And anybody who is a true supercar sports sedan fan would want a lighter smaller car.
I don't quite get your hostility.
If this is the "funniest thread I've ever read in a car forum" than this must be the first one you've been to.
The E class is a higher end automobile than the C.
And like every other car maker, minus VW, Mercedes doesn't like to compete with itself. That said the C63 is German automotive buy of the year, IMO.
1. The "detuning" of 55 models is BS, this is a fact. Didn't we already see that both SL55 and E55 dyno around 435whp stock when E55 is supposed to have 469hp and SL55 is supposed to have 510hp. In many cases, stock E55 actually dyno higher than SL55.
2. All 63 Models run the same times in the 1/4 mile even though there is supposed to be a difference in power. CLK63 Black Series and CLK63 Convertible are supposed to have a difference in power and yet accelerate at nearly identical rate, with CLK63 Convertible actually being slightly faster. Now please explain to me how a CLK with less power and more weight is able to match and exceed performance of a CLK with more power and less weight.
CLK63 Convertible (detuned) = 0-60 in 4.2, 0-100 in 9.5, 1/4 mile in 12.5 @ 116mph
CLK63 Black Series = 0-60 in 4.1, 0-100 in 9.6, 1/4 mile in 12.4 @ 115mph
I really don't see any evidence that proves there is any "detuning" going on. I would bet you 1000$ that if you'd strap a C63 and E63 on the same dyno, the same day, they will put down nearly identical whp. The only reason Mercedes quotes lower hp numbers on C63 is to make E/CLS/S63 owners feel better
No way in hell the 63 engine in the C63 will produce the same HP as the 63 motor in the E63 or CLS 63 or S63 or any other chasis. Speculating this engine is going to dyno at the same output as the other 63 models is silly.
I love the car, I love it.. I would buy the C63 in a second to track it. Its speed is not due to HP but to weight. And yes losing 600 lbs will make this car every bit as fast as the other 63 models. You get this engine to give you back the lost 50 hp and WOW!!! The C63 will dyno stock likely around 375 hp and will likely keep up just fine stock.
BS 12.4@116
CLK 63 12.5@115
also test conditions, where were the test and when, time date and locale?
I see the test of the E63 vs CLK 63 were at different tracks and different times of the year. Test the cars, same day same track.
It's never easy to get the best bang to the buck modification for a N/A engine, I wouldn't be surprised if them tuners release some kind of cam/valvetrain package or stroker kit to really unleash the power within.
To answer why they gave the CLK more ponies well you just have to look at the MSRP. The CLK55 priced closer to the E55k than to the C32/55.
It also looks like several of you earlier posters hit these numbers dead on for the C63.
0-60 C63 (4.1) M5 (4.3) E63 (4.3)
0-100 C63 (9.8) M5 (10.0) E63 (10.1)
1/4 Mile C63 (12.5) M5 (12.7) E63 (12.7)
http://www.motortrend.com/roadtests/...son/specs.html
http://www.motortrend.com/roadtests/...fications.html
