C63 AMG (W204) 2008 - 2015
Full C63 AMG review from Top Gear
Old Aug 29, 2007 | 10:53 AM
SilverBulletAMG's Avatar
C32 AMG
Not sure if you guys have read this yet, but if not...
DIRECT LINK
Mercedes C63 AMG
This car is a V8-powered dump of rain on the new BMW M3's parade. Mercedes held a driving event for four European journalists at Paul Ricard circuit in the south of France at the same time as the rest of the world's media were down the coast in Spain, driving the new M3.
Tom Ford tells that story in his blog, and - in precisely the way Mercedes planned it - I'm telling you about the C63 AMG here. Bitter rivalry? About as bitter as it gets.
We weren't given final production C63 AMGs to drive, because the launch proper will happen at the Frankfurt motor show in September, and there are still a few bugs for Mercedes to iron out. But they were close, and despite hundreds of laps of the Nürburgring, seemed tight and rattle-free.
Expect this most extreme version of Mercedes' new C-Class to be priced line-ball with the M3 at around £50,000. The C63 comes in two forms - standard and Performance Pack. The PP option will add about £4,000 and includes a higher-set speed restrictor, up from 155mph to 174mph. PP cars also get stiffer, lowered suspension, thicker anti-roll bars and a limited slip differential.
It's a track-going version, then, with a harder ride. I thrashed the living hell out of the PP at Paul Ricard, and drove the standard car more sedately on the roads around Le Castellet. I can tell you now, I wouldn't hesitate in opting for the Performance Pack. More on that later.
First, some numbers. This is the same 6.2-litre, normally aspirated V8 we've enjoyed in other monster Mercs, including the CL63 AMG.
In this level of tune, it develops 457bhp, comfortably eclipsing the new M3's 420bhp. Called the M156, it's tunable to 580bhp with relative ease, and AMG engineers describe it as 'unstressed' at 457bhp. This is one the world's great engines.
It's worth noting that it develops its max power at 6,800rpm and revs to well over 7,000rpm. So it's packed with high-tech stuff, like variable cams, magnesium intake manifolds, aluminium crank case, clever valves and tappets, expensive low-friction coating on the cylinders and other expensive things, and it's also blessed with 6208cc's of bigness - 443lb ft of torque kicks in at 5,000rpm.
Again, that seems a high rev point, but a minimum of 370lb ft is available from 2,000rpm all the way through to 6,250rpm. That's cubic capacity for you. Get the picture? Revvy AND big. In a smallish, rear-drive saloon weighing 1,730kg. The noise is fantastic, too. If you've heard the safety car at F1 races, then you'll know all about its big-chested V8 roar.
And here are two more numbers before we get behind the wheel - according to official weights from BMW and Mercedes, the AMG engine weighs 199kg, compared to 202kg for the M3's four-litre V8. So it's light for its size.
It's all down to the influence of Bernd Rammler, the engine's creator. His CV isn't too shoddy - he designed the Porsche Carrera GT's V10, along with many DTM (German Touring Car) engines of the past. A master, is our Bernd.
Anyway, you can now forget all of that high-tech wizardry, because it pales into insignificance next to a simple plastic switch on the centre of the dashboard. It's marked 'ESP', 'SPORT' and 'OFF'. The last of those words is by far the most interesting. This is the switch for the Electronic Stability Control programme - press it for a few moments and a light on the dashboard tells you ESP is off.
When Tobias Moers, AMG's head of development, explained this in the Paul Ricard pitlane before I took to the track, within two trilliseconds I'd asked whether it meant 'off' or 'not-quite-f**king-off', the annoying killjoy mode that ruined previous AMGs on the track, where the computer lets you slide a little bit before cutting the power abruptly.
"It means off," said Moers with a smile. "Try it out on the track, be my guest. If you get it wrong, you will spin. It comes on again if you hit the brakes. Enjoy."
Yes, yes. A fast, focused Merc that you can enjoy on a circuit. This is the beginning of an important awakening for the three-pointed star and we approve.
It's all very noble and proper, having an ESP safety net for every car in the range, and that's how things have been before this one, even on AMGs - now, Mercedes is taking a good look at the market and realising that serious drivers, the kind who are willing to accept responsibility for a spin, are paying big bucks for cars that allow them to switch ESP off. Like the BMW M3.
Moers was keen for this little 'off' button to mean 'off' and the final decision is the right one.
This car will give the new M3 a very hard time indeed. Unlike the CLK63 Cabriolet I drove recently, the chassis isn't overwhelmed by the incredible power and torque of the engine. It not only copes, it feels natural.
Look at the oversteer photos on these pages and be aware that the car is flattering its driver. Drifting a C63 on a circuit like Paul Ricard, with big run-off areas and a smooth surface, is amazing fun.
Even on brand new Bridgestone tyres - now wasted, sorry - the rear end kicks out instantly with a quick lift and squirt of the throttle. The engine has so much torque, it requires no finesse. And once the tail's hung right out there, the steering has enough feel and quickness - and, crucially, the chassis enough precision and tautness - to give you the confidence you need.
Moers and his chassis team have done some good work, starting with a new front axle borrowed from the CLK63 Black Series. There's a wider track front and rear than the standard C-Class, and uprated springs, dampers and anti-roll bars, honed over countless laps of the Nürburgring. The result is the most focused Mercedes for 18 years - you need to go back to the 190 2.5-16 EVO for any sort of comparison.
You still have the option of leaving the ESP on, of course, which activates the moment the wheels slip and is fine for road use - or choose 'sport', which allows a lot more drift before the engine cuts power. Moers says that the lap time around the Nürburgring with the ESP set to 'sport' and 'off' is identical.
Bernd Schnieder, five-times DTM champion with Mercedes, was on hand to demonstrate just how fast the car would travel around Paul Ricard. Yes, it's fast alright. And having Schnieder there rammed home the point that Mercedes is capable of making a tin-top car lap a track quickly. BMW hasn't dared take on Mercedes in the DTM.
The car looks good, too - not overblown, but understated and quietly evil in the way a fast Mercedes should be. That includes the twin bonnet bulges, which are purely cosmetic, 19-inch titanium grey wheels (18s are standard) and excellent dark inserts in the headlight clusters. The whole effect is superb.
What doesn't work so well - yet - is the transmission. The 7G-TRONIC seven-speed automatic is smooth enough when left to its own devices on the road, but it's too slow to react in manual mode - you hit the paddle behind the steering wheel and there's almost one second's delay before the car changes gear, up or down.
That's not good enough, especially when the new M3 will come with a dual-clutch robotised manual from next March, which will give instant changes. Hopefully, AMG can work some magic here before the car hits the showroom.
Interesting that we're almost at the end of the story and I haven't mentioned the car's performance on the road. That's a good sign, because its prowess on the track speaks volumes.
The roads around Le Castellet are too smooth to make a final judgement on ride quality, but I'd hazard a guess that the stiffer suspension of the Performance Pack version still has enough compliance to make it comfortable in most conditions. I'll never have the money to buy one of these cars, but if I did, I'd splurge the extra few grand for the PP spec.
The standard car still handles well, but it's significantly softer. Once we've tried them on British roads, we'll make a proper judgement. The new C-Class's best qualities are all here, though - superb build quality and trim materials, high levels of refinement and a comfortable cabin, front and rear. Especially so with the superb AMG bucket seats.
Ultimately, a comparison between the CL63 AMG and the new BMW M3 - and we shouldn't forget the Audi RS4, a car the AMG boys have studied closely and respect greatly - will be close, and will boil down to what the owner wants from the machine.
Maybe the M3 will be more precise, the Merc a better all-rounder, with the Audi somewhere in between as the best all-weather car. But 'all-rounder' might not be good enough.
Talking to AMG boss Volker Mornhinweg , seems like he's aiming to beat BMW M-Sport at its own game. I told him I didn't like the transmission much, thought it was too slack and soft, and his eyes lit up at that.
"Just wait," he said. He wouldn't tell me what he's up to, but he's definitely up to something.
Bill Thomas
Old Aug 29, 2007 | 11:22 AM
ItalianStallion's Avatar
R35 GT-R, EvoX
Originally Posted by SilverBulletAMG
Talking to AMG boss Volker Mornhinweg...I told him I didn't like the transmission much, thought it was too slack and soft, and his eyes lit up at that.
Excellent article, I'm very excited about this car. The above quote is still the most exciting news I've heard from Mercedes in a long time...its gotta be DSG!
AMG+DSG transmission=Everything you could ever wish for in a car, period.
Old Aug 29, 2007 | 11:27 AM
C32 AMG
PLUS the LSD and full OFF for the ESP! Not to mention the unglodly amount of headroom this motor has. If they end up with the much needed DSG along with everything else, this car is the KO king taking out every M car almost as well as the RS4. This will be one of the best cars under $80K!
Old Aug 29, 2007 | 04:38 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
already posted:
https://mbworld.org/forums/c63-amg-w204/205473-top-gear-review-c63.html
Old Aug 29, 2007 | 06:12 PM
TopGun32's Avatar
DSG!
Most likely DSG will be offered by the M3 first and the C63 probably in about another 12 months.
so far.. all the european articles have been excellent.. can't wait to read the american mags for thier take.
Old Aug 29, 2007 | 06:36 PM
360_iti's Avatar
W203, W211, W219, W212
Originally Posted by TopGun32
DSG!
About C63 ? Go to a bookstore and ge the Sept issue of Motor Trend and C&D.
Old Aug 29, 2007 | 06:45 PM
2PHAST's Avatar
500E Signal Rot
How do we get from project MSRP from $60,000 all the way up to $100,000?
Old Aug 30, 2007 | 10:18 AM
C32 AMG
Huh?! Who said anything about a $100K C63??
Old Aug 30, 2007 | 11:21 AM
Bones's Avatar
e55
The CLK Black is priced at $135,000
Old Aug 30, 2007 | 11:41 AM
C32 AMG
LOL Whoops! I knew that....honest, I did...haha
Old Aug 30, 2007 | 12:11 PM
Carl Lassiter's Avatar
'08 M5, '10 Land Cruiser
Wink
Get the hammer back out for one of the numerous reposted threads that make things feel like groundhog day on this forum.
Old Aug 30, 2007 | 04:23 PM
TopGun32's Avatar
cool!
I think that issue basically recaps the reviews in europe. But we have not see the testing on this side of the pond.
I'm waiting for testing to be done here in N.AMerica and around So Cal where MT using tests.
Hopefully they can get an M3 and RS4 and have a comparison test.
I doubt we will such test until later this year, since the won't be released until 1st Quarter of 2008.
Old Aug 31, 2007 | 05:41 AM
ash-c32's Avatar
996 C4, previously owned 996 c2, c32 amg, 350z, R33 GTR, R34 GTR
DSG is rubbish for driver pleasure - I want a Manual
Old Aug 31, 2007 | 08:16 AM
R35 GT-R, EvoX
In an AMG, it'll never happen. DSG is the closest you'll get. Plus, out of all transmissions, it is definitely the best (performance-wise). They're supposed to be mad smooth as well as opposed to bimmer's SMG.
BMW is also supposed to release a new DSG tranny this spring for the M3.
Old Aug 31, 2007 | 05:24 PM
TopGun32's Avatar
ditto.
I rather have DSG. Faster than manual and automatic program for the wife.
DSG are becoming more common.
Audi/VW
Mitsu Evo X
BMW and MB
Old Sep 2, 2007 | 06:55 AM
Andy7oaks's Avatar
I bet when the British journo's test in the Uk on our rubbishy roads they will all be saying they want the LSD but on the softer suspension of the none performance pack. Hopefully the LSD can be offered on it's own if this is the case for us Brits.
Regards
Andy
Old Sep 4, 2007 | 06:12 PM
*SilverArrow*'s Avatar
AMG E36
I remember a time on a N/A engine that was the sole province of the Supercars...
Man has it all changed...
I wonder what a stroker would be capable of...?
