C63 reliability?
That said, there are two reasons for you to relax. One is that AMG goes to great lengths to minimize any reduction in reliability. It won't be more reliable, but it's about as close to the same reliability as is possible for a high-performance version.
But more importantly the latest MB models, the W221 S/CL-Class and the W204 C-Class have been built from the bottom up with reliability in mind. Time will tell for sure, but the W221 seems to bear out that MB has turned the corner on the quality problems that plagued it for the last decade.
refused to start 3 times, for the same fuel pump issue - replaced after and after again
cracked bushings - replaced
moonroof that doesn't fully retract with one-touch - adjusted moonroof cable
supercharger produced strange noise - replaced
It hasn't been reliable, and I suggest staying away from new MBs in their first year. 04 however, was the 3rd year for the C32
A lot of people have problems with C32's though isn't that correct? I believe Mercedes is past their horrible reliability stage. Luckily my C43 is before that stage, and hopefully when I purchase a C63 it will be after that stage.
If taking your car in for a service a couple times is the end of the world to you, then yeah, you might wanna skip the C63. MB has been great about taking car of any issues. I'm #2 on my local waiting list for the C63. I don't mind taking the car in to resolve a few first year quirks.
MB has spent $Millions of dollars to improve on its reliability and initial quality... and the results are starting to appear.. check out JD Power and Assoc.
they not the best, but moving up
I would say the C63 will be more reliable then the C55 but will not be in the Lexus level of quality and reliability.
Our '06 RSX Type-S? Absolutely nothing in the 14 months we've owned it other than oil changes.
This all said, the C32 is a very cool car! I love it. Very laid back and comfortable most of the time but accelerates like a Hemi Cuda when you hit the gas. I'd buy it again in a second. So I don't know if I'd avoid a C63 merely because of reliability worries. My attitude is I'll put up with some measure of you-know-what if the underlying car is really good. MB definitely needs to improve here but the AMG products are so well engineered, it to some extent makes up for it. Now, if I was having these problems with a Camry or Taurus, I don't know if I'd be as forgiving. My $.02.
the prior owner took care of it at the dealer, his only complaint was that it took 2 trips to get the parking sensor fixed. other than that, i haven't done anything w/ my car other than change the oil using synethetic and drive it. i do believe people when they say the NA engines are fairly bullet proof...perhaps that will apply to the E63 also.
