Performance Pack???
So based on what I have read, the performance package will include ceramic brakes, lowered suspension or stiffer springs, limited slip diff, alacantra steering wheel and a re-mapped ecu that raises the governed speed to 174mph. Apparently the 19 inch wheels will be available but only as an option with the PP. The performance pack is expected to add 5k to the price of the car.
I don't plan on using the car on the track and will use it as my daily driver. On several reviews I have read, the performance pack makes a huge difference on the track and the "stock" seems much softer in comparison.
My question to the board would be if I'm not planning on tracking the car, do I really need to performance pack? I really don't want my fillings knocked out every time I drive the car and as I mentioned I have a pretty lengthy commute (plus a bad back to boot)
My real dilemma is that those 19 inch wheels look soooo rad! I also don't know if the limited slip is a big deal or not since I won't truly be testing the cars limits on a regular basis. I'm not really partial to the lower suspension or the alacantra steering wheel since I've heard bad things about alacantra (heavy sweating issues apparently).
So I'm torn about whether or not I should just go all out on the car and get the PP or be more conservative and go stock.
Based on my described use, what do you guys think???
Thanks in advance for your advice
- Same size rims, but 2 piece (lighter and stronger)
- Slightly bigger caliper
- LSD
- ECU limiter increased from 155 to 174 mph
- An additional $5,500
- Bigger rims, also 2 piece (lighter and stronger)
- Slightly bigger caliper, brakes, rotors
- LSD
- Alacantra grips steering wheel
- $7,500
Whatever Mercedes finally decides, you can actually have the best of both world. You can order ONLY the rims on the performance package, but not the whole package itself. This will costly extra of course, but you'll get only what you want/need as opposed to the whole package.
If you say you have back problems and long commutes, then you are better off buying a used CL55 AMG because the C-Class's seats are not the most comfortable in the world. The CL-Class, however, has the best, most comfortable and most luxurious seats Mercedes ever made. The car is very roomy, very smooth, and very comfy. It is made for long commutes and relaxation yet still have the AMG power-house engine. And if you must have a 4-door, you can always go for S55 AMG.
Either way, these cars are awsome, and you definately won't be disapointed.
Good luck....
If you do not get the mechanical LSD the electronics try to replicate this it seems, but apparently it is a bit on-off so you get an inside wheel spinning and then the slide as the brain works it out, not too smooth a transition.
This is all hearsay of course, need to get more data and reports to have the ground firm beneath our feet.
Regards
Andy
Well at least that settles my dilemma; I really liked the wheels but now that they won't even be available here, there's really no point inthe PP for me. Now my only remaining dilemma will be about color...carbon black or that dark grey???
Did Rob say when you could expect delivery? The guys at MB Austin are pretty clueless about anything related to the car.
Cars should be out late next year in the US....and I stress "should" because the dealers know less than the people on this site.
Airmatic suspension with adapative damping gives each wheel the ability to react to actual road conditions verus having a fix shock/strut setting. In addition, it compensates big time for body roll (you can take a corner feeling the car is level-no roll) Without all this electronics it may feel like a harsher ride.
The larger rim size will also contribute to a harsher ride due to the smaller side wall. The 030 option also includes upgraded tire speed and load ratings for the 186 mph speed limiter. Another reason that this is must for hi performance.
Just my $.02, I would not buy an AMG unless it has the 030 option.
