What is the normal engine temp?
If you go into the AMG mode on the steering wheel you can monitor the temps better.
The big of an engine stuffed into that small of a engine bay is going to produce a lot of heat.
(arrow > until you reach "Configurations" or "Car Options") Configurations (click ok on the steering wheel to proceed)> Measures and units (click OK to change).
I also regularily see 105c which is norma. For these engines.
Originally Posted by bhamg
In the past week during 85-96˚F daytime temps:
Oil temp: 215-217˚F
Water temp: 195-197˚F
Some of my friends with other high performance cars have "lower-temp" thermostats, and they swear by them, especially in hot weather. But for the C63 AMG, it's not really much of a topic of discussion as most would say that the C63 AMG doesn't suffer much from "heat soak" or run too hot.
However, it seems that MTHIS, hhughes1, Dads C63, and a few others also have the MHP 180 degree F T-stat...just wondering if this "lower-temp" T-stat makes a difference on the C63 AMG, whether it be on the track and/or for everyday driving.
