C63 AMG (W204) 2008 - 2015
What is the normal engine temp?
Old Sep 19, 2008 | 09:04 AM
GBlansten's Avatar
2017 BMW X5M DG/AB
My C63 reads above 80 (probably around 90 celcius). Is that normal? I just got it and it runs well and no error codes.
Old Sep 19, 2008 | 10:00 AM
radrads203's Avatar
00 E430 05 S203 08 C63
thats what my gauge readings too... so i guess our engines are a bit on the hot side
Old Sep 19, 2008 | 11:20 AM
GBlansten's Avatar
2017 BMW X5M DG/AB
Thanks a million. The AMG display gave the temp as 195-197 fahrenheit. My guage is reading exactly as yours is. I'm guessing that is normal. I was just doing a morning commute and not thrashing the car as well.
Old Sep 19, 2008 | 11:42 AM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
These engines run real hot, if i had a frozen dinner to defrost, i would simply place it under the car and.....presto ready in five minutes!
Old Sep 19, 2008 | 02:48 PM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
If I remember right, every MB that I have owned has ran just over 80 degree's celcius and you have to remember thats a **** load of motor cramned in a small space (little airflow)
Old Sep 19, 2008 | 04:12 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Thanks for the added replies guys. It makes sense that a 6.2 liter howitzer runs hotter than a Camry.
Old Sep 19, 2008 | 05:14 PM
Untertürkheim's Avatar
Also, those pictures looked were taken while stopped. These cars often run cooler at high speed (90+mph).
Old Sep 19, 2008 | 05:43 PM
mrtesting's Avatar
09' C63 AMG (Gisele)
I agree. My car runs at around the same temperature at most times too, and during hot days it runs a bit hotter too. Generally all cars run hotter when driving through the city traffic. However the engine on this car runs much much cooler and acts much more responsive when it is on a high way at high speeds.
Old Sep 19, 2008 | 08:10 PM
Balz's Avatar
C63, LR3
mine runs the same...pretty hot
Old Sep 19, 2008 | 08:30 PM
mrwolf's Avatar
08 C63 AMG, 09 Range Rover Sport Supercharged, 09 Audi A8L, 09 Ferrari California, 08 S Class
Mine regularly runs into 103-107... is that bad? You guys have me worried now!
Old Sep 19, 2008 | 08:32 PM
From what I know, it should not go over 100, ever.
Old Sep 19, 2008 | 08:36 PM
SeeKlasse's Avatar
'98 C43 AMG. Obsidian Blk w/2 tone slvr/blk interior
the fuel economy posted in the picture is 12.5 mpg roughly... thats pretty low
Old Sep 19, 2008 | 08:40 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
That's what I'm getting so far.
Old Sep 19, 2008 | 10:00 PM
gravedgr's Avatar
2009 C63 Capri Blue
Says who? Mine regularly runs at 210-212 F.
Old Sep 19, 2008 | 10:07 PM
Is the readout for the W204 in Fahrenheit now? I meant 100 Celsius, sorry for the confusion.
212F would be 100C, is it that hot at speed also?
Old Sep 19, 2008 | 10:14 PM
gravedgr's Avatar
2009 C63 Capri Blue
You can change between C and F - I set mine to F (US). I wasn't driving at highway speeds, but I did keep checking to see what the normal operating temp. was. I always wait for my oil to heat up before driving any of my cars hard.
Old Sep 19, 2008 | 10:21 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
Actual guage for US market is Celcius 80-120. The little menus on the dash that the buttons on the left part of the steering wheel let you run through nav/audio/telephone and then you come to the AMG one. That electronically displays the oil then engine temps in Fahrenheit.
Old Sep 19, 2008 | 10:26 PM
gravedgr's Avatar
2009 C63 Capri Blue
That's the one I'm talking about. I think you can set it to Farenheit or Celsius. Either way, that's what I'm using for my temps.
Old Sep 19, 2008 | 10:30 PM
That explains it, we were talking about coolant temp before.
Old Sep 19, 2008 | 10:32 PM
gravedgr's Avatar
2009 C63 Capri Blue
Ahhh, sorry for the confusion. I saw the images, but didn't pay attention to the fact that you were looking at the guage and not the digital readout. Coolant temp is insignificant compared to oil temp IMO, so I never look at mine that much.
Old Sep 20, 2008 | 03:04 AM
AMGC60-3's Avatar
Well it shows that your outside temp is 31 celcius (approx 86 degrees) and that you are just sitting there in idle and to me it all looks normal considering the condition that your in. Under normal driving ops and not just sitting there while heat builds up in the engine bay and you have air circulation the temp should run just over 80 degree's cel.
Old Sep 20, 2008 | 04:25 AM
ohlord's Avatar
Most modern
mercedes engines thermostats are set to open fully at 87c ,you are just fine.
Old Dec 7, 2008 | 09:26 AM
KingdomCome's Avatar
C63
Your high beams are on.
Old Dec 7, 2008 | 09:53 AM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Not....
Old Dec 7, 2008 | 10:31 AM
wuyichao's Avatar
C63
SL500 runs at approximately 100 Celcius
my c63 is about the same
