C63 AMG (W204) 2008 - 2015
engine temp
Old Oct 4, 2008 | 09:03 PM
6.3CAMG's Avatar
Mercedes C63 AMG
engine temp
hi all i wanted to ask that after driving the car hard for a while the oil temp gets up to 129C is this normal ???
Old Oct 4, 2008 | 09:20 PM
juicee63's Avatar
2011 twin turboed prius
Way too hot.
Likely wont physically hurt the engine as long as you have oil but it is not cooling fast enough. oil temps should stabilize 100-113, my car hovers at 93-102
The operating temp in your car is killing HP
Old Oct 4, 2008 | 10:56 PM
jackrycheung's Avatar
2009 Fully loaded C63 AMG - black on black and CF trim; 2006 Lexus IS250 AWD;
Originally Posted by juicee63
Way too hot.
exactly as mine
Old Oct 5, 2008 | 06:22 PM
6.3CAMG's Avatar
Mercedes C63 AMG
thanks for the replies but is there a solution and what is the possible cause for high tem the wether here is 35 max
Old Oct 5, 2008 | 07:35 PM
lomita's Avatar
C63AMG
High Temps
That temperature doesn't sound too high for mashing on it during 35C OATs.
What temps are you seeing during normal driving, that is, if you can.
Old Oct 9, 2008 | 07:44 AM
kip's Avatar
kip
E55
Just a stupid question, is your oil quality high enough and is there too much oil???
Old Oct 9, 2008 | 08:22 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The 63 engines have additional oil coolers in the front gaurds with their own cooling fan. The cooling fan doesn't even come on until the oil temp reachs approx 130C (depending on model). Normal oil temps around town are 90-110C, continuos hard driving in hot weather can give 140C temps, I have seen 145C as a max temp in extreame driving/high ambient temps.
Some 63's have a air cooler in front of the radiator as well as the fan forced cooler, some have a water/oil heat exchanger with a booster pump (coolant) for high temps with the fan forced air cooler. The oil cooling systems for these engines are pretty over engineered.......I've yet to see one overheat either coolant, engine oil or trans oil!
Old Oct 9, 2008 | 08:23 AM
Ausmbtech's Avatar
Yes, it's normal
Old Oct 9, 2008 | 11:07 PM
nutzboy's Avatar
C63 amg '08, ML 500 '03
around 220°F-228°F = 104.4°C - 108.9°C
Old Oct 11, 2008 | 01:13 AM
mthis's Avatar
Anything W/4Wheels
the most my car hit was 242F thats 117C and thats with abuse non stop for 5 min
Old Oct 11, 2008 | 02:40 AM
lomita's Avatar
C63AMG
Ambient Outside Air Temperature?
What was the ambient air temperature?
Old Oct 11, 2008 | 04:27 AM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
Yes I will agree on that. It's almost impossible to over heat a Merc motor.
Old Oct 11, 2008 | 07:01 AM
lomita's Avatar
C63AMG
Horseshoes?
Almost impossible unless there is a problem.
Old Oct 14, 2008 | 06:56 AM
wan888's Avatar
G55, SL55
I had a run with a 997TT last night .. weather is around 25degree celcius. After the run, my oil temp is 135 degree.
The car is hot!
Old Oct 14, 2008 | 05:36 PM
Rickenbacker's Avatar
C63 AMG
102 degrees
Drove my for 350 miles today, max temp was 102 degrees.
speeds up to 120
average 63 mph
fuel consumption at 18.6 mpg.
Old Oct 14, 2008 | 05:49 PM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Damn the C63s run hot! My Clk55 max temp is 95c when the aux fans kickin. My C36 105c when the aux fans kick.
Old Oct 14, 2008 | 07:28 PM
Jae Duk's Avatar
'09 C63
Yes, it's normal
It seems pretty normal...maybe a little too hot...mine runs at about 170-195 F. The engine seems to get pretty hot too...around 170ish F
Old Oct 14, 2008 | 07:46 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
I've put my car through a lot of abuse including back to back runs, and oil temps never exceeded 118 C. Under normal driving conditions, my oil temp is between 92 C to 102 C.
In my opinion, 129 C is too high. Something is not right, you should visit the dealership, and have it checked.
Old Oct 14, 2008 | 08:20 PM
Strafe1's Avatar
2021 E63 S Sedan
215 F at highway speeds for me. That's about 102 C.
Old Oct 15, 2008 | 01:21 AM
mthis's Avatar
Anything W/4Wheels
about 50F to 55F i get my car to that point almost everyday. but for some reason it wont go any hotter. i did try in the summer still the same 242F max.
