problems with c63
Just wanted to know if anyone is having issues with the c63. I have an 08 and this is the 4th time i have taken it in because the tire pressure monitor sensor keeps going off and on occasion, the check engine oil and next refueling sensor comes on. Three times already, MB service ppl say there is nothing wrong with tire pressure and they cant figure out the engine oil problem but there is no leak. Also, i have horrible break sqeal with this car. In fact, sometimes, it is embarrasing to drive around town and it sqeals right before a full stop and from trafic light to trafic light. They say this is normal but i have drive M3s and 911s with big breaks and they dont sqeal like these. I have taken it in again and sat with the service foreman and he said they will fix the sensors but cant promise anything about the brakes.
If anyone is having the same kind of problems, could you please share and offer any suggestions. Thank you.
My wifes BMW Z4M did the same thing with the tire pressure monitor.
I had to overfill by a couple PSI. IN Fact my GT3 did that too.
Had to over fill by a couple PSI. I mean like 2 PSI not 20 lbs.
try it and see if it works.
I dont know what brake pad to suggest but every aggressive car I have had
has a brake squeal or noisy brakes. Especially the PCCBs on the two GT3s I had. I just lived with it.
So i got the car back from the dealer today and they told me that i had a tiny nail in the rear tire, which they discovered the 4th time i brought it in and they said that would account for the tire pressure monitor. As far as the engine oil sensor, they said it was low 2 quarts, despite the fact that i have already put in a quart 2 months ago, they said this is not uncommon with amgs.
My biggest issue now with them is that they told me i need new rear tires and the tread is finished, in the center of the tires, not the outer edge. I told them i have never raced my car or peeled off the line so i dont understand how i need new tires after only 8k miles. Again, they said this is normal wear due to heavy torque to rear tires but i just dont believe that i would need new tires every 8k miles or so. Anyone think differently? Thanks again.
How many high performance cars have you owned? Not trying to be mean just trying to understand. You need to readjust your thinking with these kinds of cars. The P Zero is an aggressive tire. Not TOO aggressive but still aggressive.
The wear rating is in the 200's. My GT3 tires wore out in 4,500 miles without me racing or being aggressive. The wear rating on that tire (Michellin Pilot Sport Cups) was around 80. So this tire the Pzero is twice that. Guess what you got 8,500 miles. Just about right. I had a very similar tire in the Michellin Pilot Sport 2 Same basic wear rating 250 or 280 something like that. So youre going to get around 8000 to 10000 miles without tracking it.
Track it and the wear is going to be faster.
You are just about right at 8500. This car is a monster. its close to a race car right out of the box. Brake pads oil tires are going to be consumables on this car. THink of it that way and you dont feel so bad when you have to replace stuff. Its the cost of doing business with this car.
Guys who track will use 1 set of tires, a set of brake pads and a oil change EVERY weekend.
Hope this helps
Hope this helps
Lower the tire pressure.
We started using the Kumhos for our G35, and they're wearing great at the right price:
http://www.kumhotireusa.com/tires/pa...performance.do
The C63's gonna take some getting used to in the tire wear dept...
do a search on bedding in brake pads or google it.
there is a elaborate process involving driving to 70 or so
and smashing on the brakes and repeating to bed in the pads
This might make the squeal go away.
Hope this helps.
Paul G
