C63 AMG (W204) 2008 - 2015
CAM Sensor @ 7k miles...
Old Oct 8, 2008 | 06:23 PM
ARC101's Avatar
2008 C63
I remember a few of you posting about a CAM sensor that needed to be replaced however, I did not remember reading how the car behaved.
I was merging onto the highway and slapped the throttle to get in front of a truck that was dropping dirt on the road. I quickly accelerated from 70 to about 110 and then exited at the next off ramp. By the time I reached the end of the ramp the car felt as if it was misfiring badly. Wasn't sure if I was going to make it another mile to my office with the car stalling. It never stalled but the check engine light turned on and limped to the office.
I turned off the car and then turned it back on to see if it would start. It fired right up without the check engine light and ran perfectly.
I dropped the car for service and once connected it showed a misfire on an entire side of the engine. They are going to replace the sensor and said it should be as good as new.
HAS ANYONE ELSE HAD THIS EXPERIENCE....? Please post or PM...
Old Oct 8, 2008 | 10:58 PM
passcheco
Guest
Posts: n/a
I had the same issue at 60 miles and the dealer told me was a purge valve.
Old Oct 8, 2008 | 11:19 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Had the same issue at 800 miles - fixed while I waited.
Old Oct 9, 2008 | 12:18 AM
radrads203's Avatar
00 E430 05 S203 08 C63
had the same issue when my car reached 1000km ..
Old Oct 9, 2008 | 03:09 AM
Hans Delbruck's Avatar
What I like!
Had a bad cam position sensor at 60 miles. No major symptoms except for the yellow CE light... but, I was taking it easy at the time because I had just bought the car. I heard a slight pinging under accelleration, but only once. After that I made sure I was light on the throttle. The dealer said it was OK to drive while they waited for the part, so I drove it home. No further issues after they replaced the sensor.
Old May 28, 2009 | 04:01 PM
drawde's Avatar
2009 C63
Anyone know for sure if the cam sensor problem is a 2008 problem? Was it fixed in 2009?
Old May 29, 2009 | 12:03 AM
mthis's Avatar
Anything W/4Wheels
i have a 08 and dint have that problem yet. i do have alot of other problems do. lol
