C63 AMG (W204) 2008 - 2015
Need help with using iPod in my c63 and with homelink...
Old Dec 4, 2008 | 12:34 AM
CPD SLK's Avatar
2009 C63 AMG
I hooked up it up to the iPod connector and the connection seems fine. It started playing music from my ipod, but I couldn't control the music either from my ipod in the glove box, or the command unit?
The screen in the iPod just has a MB star on it and says, "hit ok to disconnect."
I can't go to any other screen on the iPod, and the scan buttons on the command unit didn't work either. Am I missing something?
My second issue is that I can't seem to get my homelink working. I held the #1 and 3 buttons until I got the fast blink. Then I held my gate opener and the #1 button at the same time, but all I got was the slow blink...it never went to fast blink. What am I doing wrong?
Old Dec 4, 2008 | 01:11 AM
jtdominate's Avatar
C63
To control the iPod you have to press the right arrow on multi-function button on the left side of the steering wheel until you get to Audio. You'll see the track title. Just scroll through with the up and down arrows. It sucks that you can't control the iPod from the screen.
As for the gate opener. Is it a garage door or a community gate. If it's the latter, it may not work. I encountered that problem in my last condo with the Homelink systems in a Porsche and Chevy. The step your missing is that you have to program the opener to learn mode and then start the learning procedure holding #1 & #3.
Hope this helps.
Old Dec 4, 2008 | 02:26 AM
CPD SLK's Avatar
2009 C63 AMG
The manual does not mention a learning mode....only the press down #1 and 3 to clear all codes and start programming.
And yes...it's a community gate...but the sales guy said it should still work.
Old Dec 4, 2008 | 09:15 AM
norb's Avatar
2009 C63 AMG
Press the homelink button, keep it pressed, then hold up the remote and press the button once and let it to. Wait for rapid flash. Done!
Old Dec 4, 2008 | 02:21 PM
CPD SLK's Avatar
2009 C63 AMG
Uh....I dont think there is a "homelink button"???
Anyone want to advise me of whether I'm right or not.
Old Dec 15, 2008 | 06:49 PM
jtdominate's Avatar
C63
The Homelink button is whatever button you decide to use to program the opener.
Uhhh...the sales guy said it would work. Dude most of them they know next to nothing. I'm almost sure it won't pogram since the gates use a rolling code. That gate has to be put into a "program mode" to send the signal to the transmitter. When I asked my property manager she said they wouldn't do it. I rationalized that it was because when I moved out I could theoretically still have access to the "private property".
