C63 AMG (W204) 2008 - 2015
what type of oil does MB dealer use?
Old Dec 28, 2008 | 07:49 PM
  #51
MB_Forever's Avatar
E63 P30, CL500 Sport
Originally Posted by ShanSL350
Has anyone managed to get to the bottom of this yet?
When i collected my car i was given a small 2.5ltr Mobil 1 0-40w container of oil and told that its not uncommon for the cars to need a top up during or just after the run in period.
I have checked with the local dealer and the service department and they told me 0-40w is the recommend viscosity.
I am UK based so just wondered if anyone has heard any differently?
Most dealers are lazy and don't keep everything up to date. They are probably just going by what's recommended by your manual, which is 0W-40. AMG stated that 5W-40 is now the recommended oil and have confirmed it through a TSB in May of 2008. So, if your dealer can't get Mobile 5W-40, you can always order it, and take it to them when changing oil next time. I think 0W-40 won't hurt either, but I'm just not sure why they issued the switch
Old Dec 29, 2008 | 06:50 AM
  #52
Untertürkheim's Avatar
Read post 27 and on.
Old Dec 29, 2008 | 10:32 AM
  #53
ShanSL350's Avatar
C63 AMG
I had been reading the whole post and the reason i asked the question was that 05-40w was for everyone outside the USA but i had only called my dealer last week and they told me 0-40w.
I think as mentioned its probably lazyness on the dealers part, i will ask them to double check for me
Shan
Old Dec 29, 2008 | 11:23 AM
  #54
MRAMG1's Avatar
S600, GL450, GLC 43
Gentlemen:
Without going into great detail about oils, your engine or even a lab would have a VERY dificult time distinguishing between 0-40 and 5-40 weight synthetic oils. You will NOT do ANY damage to your engine or warrenty using either one here. The ONLY difference would be IF the oil SPEC was different, NOT weight, aka the additive package is what I am talking about here guys. My ex crew cheif worked for a research lab on oils, and I will gladly wager anything you like on this one. Oh well, read the label, and if they are the same spec whcih they should be, you will be just fine.
See yeah
PS: USE SEARCH ON THIS TOPIC PLEASE, as it has been discussed in GREAT depth on this site.
Old Dec 31, 2008 | 07:03 AM
  #55
Shan
Like another poster said, as long as it is 229.5 approved, and -40 weight or higher, it is good for your car.
As far as I know, there are three oils that meet these requirements:https://mbworld.org/forums/3202814-post16.html
Old Aug 5, 2018 | 09:06 PM
  #56
FactoryFast's Avatar
2014 C63
Angry
I just got my report back from Blackstone Laboratories and the dealer is using 5w30 in my engine. When I asked my tech via text he said thats what they have on tap. Suggestions? Recommendations?
Old Aug 9, 2018 | 09:47 PM
  #57
AA717driver's Avatar
‘04 996 C4S, ‘18 GLC, ‘19 Alltrack
I bought a filter at the dealer today. He tried to sell me MB Performance oil. He says it’s new for AMG’s.
Its made by Mobil. I’ll stick with M1 0w-40.
TC
Old Aug 10, 2018 | 08:35 AM
  #58
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
My last 2 oil changes at the dealer have been 5w-40
Old Aug 11, 2018 | 02:17 PM
  #59
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Yes... two. (1) Show the idiots at the dealership that only 0W-40 and 5W-40 oils are allowed in the M156 motor and get them to flush that crap out of the engine ASAP (including the oil cooler) and replace with a proper 0W-40 or 5W-40 grade oil at their cost while you watch and make sure that they do it right, and furthermore get them to admit IN WRITING that they put in an unapproved thinner oil which may have already caused some damage and excessive wear to your motor so that if 5h!t happens and you're looking at $50K bill for an engine rebuild you at least have the possibility of a recourse. (2) Find another dealership or indie shop to service your car going forward.
Old Aug 11, 2018 | 02:20 PM
  #60
Diabolis's Avatar
TC
Yup... Imperial oil now makes the MB oils again, but I too stick with off-the-shelf M1 0W-40 over the MB "energy-saving" concoction regardless of who makes it.
Old Aug 11, 2018 | 05:21 PM
  #61
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by wuyichao
as title
what type of oil does MB dealer use when they do an oil change?
do they use a specific type of engine oil for the AMG models?
thanks!
Here are the two pertinent specs that relate to the oils. The 223.2 spec drives you to which grades are allowed. The only grades for car in the US is 229.5, and you can use either 0W-40 or 5W-40 only. The 229.5 spec gives you the oils that MB has approved. There are many, many brands and types available in the 0W-40 and 5W-40 in the 229.5 spec.
I believe MB recently moved to an MB branded oil at the dealers, and it's unclear which brand. In any event, only 229.5 spec oil in 0W-40 or 5W-40 should be used.
Regards,
Joe
File Type: pdf
Old Aug 12, 2018 | 10:46 PM
  #62
looney100's Avatar
None
MB oil is made to MB specs. Just because it’s made by someone who also makes some other brand of oil doesn’t mean they are of the same quality.
Old Aug 13, 2018 | 09:01 AM
  #63
Diabolis's Avatar
Precisely.
Old Aug 13, 2018 | 12:45 PM
  #64
chrisridebike8's Avatar
'10 C63
This! I went to MB Fresno because I was getting low on oil and just wanted a top off to hold me over a couple hundred miles before I changed the oil myself. The parts dept tried to sell me 5W-30. I had to ARGUE with the guy that I needed 5W-40. He kept telling me that all MB engines use 5W-30 now. I asked him to look it up and stated that our motors needed 5W-40 229.5 spec. Eventually he found out he was wrong. If I hadn't been informed, I would have put the wrong oil in! I will never take my car there and is a major reason I do a lot of maintenance myself or take it to a good indy shop when the job is too time consuming or too complicated for me to do.
