C63 AMG (W204) 2008 - 2015
Engineering Menu Question
Old Jan 14, 2009 | 10:45 AM
qship5's Avatar
M5, C63, 335Ci
I'm trying to figure out how to change the logo on the COMAND screen from the MB star to the AMG logo and had a question regarding one of the options in the engineering menus. I don't see a setting to select anything AMG like some of the other COMAND systems supposedly have based on posts I read on benzworld. I did however see an option under the "Display" menu called "Sample image from PCMCIA Card" Does anyone know what this does? If I load a jpeg of the AMG logo on my memory card can I pull it off there and replace the MB star? If so, does anyone know the correct image size to properly fill the screen on the COMAND display?
TIA,
Mike
Old Jan 14, 2009 | 10:53 AM
scarbrtj's Avatar
AMG C63 S
Now *this* is something I'd like to know, hope you get an answer.
As a first step for me, how do I get to the engineering menu????????
Old Jan 14, 2009 | 11:14 AM
qship5's Avatar
M5, C63, 335Ci
Press the following three keys at the same time and hold for about 5 seconds.
Hang up, #, 1
You should see the engineering menu come up on the screen. You need to be careful what changes you make as you can really mess up your COMAND by choosing the wrong settings.
Old Jan 14, 2009 | 04:11 PM
lee7758's Avatar
Porsche 911 Carerra 4S
Hang up, #, 1
So this different with my SLK 55 AMG, mine is pressing 3,5,7 at the same time!!
Old Jan 14, 2009 | 04:55 PM
bazi 007's Avatar
c63 amg
how do u keep the amg mode in the speedometer part? mine always starts in the miles driven mode?
Old Jan 14, 2009 | 05:32 PM
qship5's Avatar
M5, C63, 335Ci
That's a little off topic, but I don't think there is a memory function that retains the last display setting for the cluster when restarting the car.
Old Jan 14, 2009 | 06:25 PM
bustopoo's Avatar
c63 amg
Thanks for that post on how to access the engineering menu!
Two questions for you:
1) How did find that trick out?
2) What do all those settings do and is there a website that decodes all the different settings?
Paul
Old Jan 14, 2009 | 08:58 PM
qship5's Avatar
M5, C63, 335Ci
I got the key combo from another forum, and I don't know what all the settings do. Trying to find out as much as I can before changing anything.
Mike
Old Jan 14, 2009 | 11:11 PM
peet's Avatar
09 C63
BTW - W204 COMAND is not COMAND APS!! So 3 5 7 should not do anything. I don't have a PCMCIA card or would try it - anyone have one? Slap a JPG on it and see what it does!
Old Jan 14, 2009 | 11:48 PM
mthis's Avatar
Anything W/4Wheels
you guys can also go on dyno mode with the c63. on the steering wheel hold the answer button and ok at the same time for 5 sec and it will apear ther. oh yea key pos, 1 and make sure all doors are closed.
Old Jan 15, 2009 | 02:22 AM
GMW's Avatar
GMW
2013 ML63 AMG PP
Nice!
Hang up, #, 1
Funnily enough, I was just wondering about how to access the engineering menu, yesterday. (even though i don't yet have my car... ) Thanks!
Old Jan 15, 2009 | 03:32 AM
mrtesting's Avatar
09' C63 AMG (Gisele)
And what exactly is the difference in Dyno mode? What are the "implications".. if you know what I mean
Old Jan 15, 2009 | 08:39 AM
mthis's Avatar
Anything W/4Wheels
hahaha try it you will be very happy.
Old Jan 15, 2009 | 09:47 PM
peet's Avatar
09 C63
Dyno mode shuts off traction control and electronic LSD thereby creating a locked rear end. It's designed to - funny enough - use on a dyno.
Old Jan 15, 2009 | 09:50 PM
tyanger's Avatar
09 C63 steel grey
no wonder the code didn't work on my car
I don't have LSD or PP
Old Jan 15, 2009 | 10:40 PM
mthis's Avatar
Anything W/4Wheels
dont matter if you do or dont have it.
ill do this set by step.
1.open the car
2.sit down and close ALL DOORS.
3. put key in pos on. 1
4. hold accept and ok at the same time for 5 - 10 sec (steering wheel)
after you should see a message that say dyno something.
Old Jan 15, 2009 | 10:42 PM
mthis's Avatar
Anything W/4Wheels
i dont have a lsd and when in dyno mode the rear end DONT LOCK. sometimes it does when it feels like it.
Old Jan 15, 2009 | 11:27 PM
mrtesting's Avatar
Hmmmm I know it is meant for use on a Dyno, but what do you assume the safety concerns could be whilst driving under the influence of Dyno mode?
Old Oct 29, 2010 | 01:17 AM
gyrex's Avatar
2010 C63, 2008 Audi TT Roadster (Sold)
TIA,
Mike
Has anyone figured out how to change the MB Star image to the AMG logo on the comand system?
Did anyone try the PCMCIA method?
