C63 AMG (W204) 2008 - 2015
oil use
Old Feb 2, 2009 | 08:14 PM
matt55's Avatar
09 c63 10 c300 Nissan truck
oil use
Those of you who had their63s for a while has anyone had to add oil? I've read that consumption varies for none to some . Planning to buy one Thursday and want to know what to expect. Thanks. Also would like to know of any issues that anyone my be having
Old Feb 2, 2009 | 08:27 PM
GBlansten's Avatar
2017 BMW X5M DG/AB
At 3K I got the light. Oil level at minimum. Added 1.6 liters as the owner's manual suggested. I'm only at 4k (miles) now.
Old Feb 2, 2009 | 08:32 PM
tyanger's Avatar
09 C63 steel grey
Have had 09 for about 4 months/3100 miles and have not had any issues with burning oil.
About 1 month ago at 2400 miles or so had to bring car to dealer for check engine light due to faulty cam sensor (or so I was told) - picked the car back up within 24 hours and it's been running fine since.
Burned up my stock 255/35 18 inch rears within 2800 miles and have since replaced them with 265/35 P Zeros. This is apparently a very common 'issue'.
Overall, I absolutely love the car. I wanted it so bad that I paid sticker for it - and it's still worth every penny.
Old Feb 2, 2009 | 11:25 PM
shaker's Avatar
2009 C63
6750 Miles on the 09 since end of July and have not had to add any oil, but mind you did have it changed at around 1900 miles. Last week when I checked I probably could have added about 1/2 to 3/4 quart but still above the lower end marks... no problems here.
Old Feb 2, 2009 | 11:44 PM
mthis's Avatar
Anything W/4Wheels
i add so much oil i have a couple box at home.
if you drive your car hard you will need to add oil if you dont need to add oil you not driving hard.
Old Feb 2, 2009 | 11:46 PM
BerBer63's Avatar
2009 C63
Where do you buy your oil from? 0W-40?
Old Feb 3, 2009 | 12:39 AM
Merc63's Avatar
C63 AMG
Why is it burning so much oil? I don't think that much oil consumption is normal?
Old Feb 3, 2009 | 01:03 AM
nutzboy's Avatar
C63 amg '08, ML 500 '03
added 2qt. (0W-40) for 1st oil check light at 3,500 miles and 2nd at 7,000 miles . That's normol for this car.
Old Feb 3, 2009 | 10:12 AM
blownS's Avatar
'12 CTS-V
I've had to add about 2 qts so far (at 4K miles rite now). I get the "Check oil level" light @ once a month. Pretty annoying, and if it's considered normal, MB's got some splaining to do IMO...
Old Feb 3, 2009 | 11:11 AM
norb's Avatar
2009 C63 AMG
Maybe you guys didn't follow AMG's break in procedure?
Old Feb 3, 2009 | 11:34 AM
blownS's Avatar
'12 CTS-V
I followed it to the "T", so that's def not the cause.
Old Feb 3, 2009 | 02:00 PM
dlbello's Avatar
2009 C63 AMG Black on Black PP Package CF fully loaded
I received my car in Sept. 2008 and have gone through close to 2 qts before my LSD and motor oil change @ 1850 mi's. I'm guessing because you're in Florida, your car most likely runs hotter for longer periods of time causing oil to dissipate faster... Just a logical guess because the dam car runs very hot! I may go with the New cooler running thermostat that are out for the C63... In Sept. I might have seen a few warm days (maybe 70's) and the car was throwing out heat like it was on fire. I can't see driving this car in 90+ degrees like this.
Old Feb 3, 2009 | 03:38 PM
blownS's Avatar
'12 CTS-V
That's an interesting theory. It's been pretty cool here the past few months tho (70's). I def noticed this car runs hotter oil temps (anywhere from 208F to 220F+) than my old E46 M3 (which was always @ 210F or less). Still, u would think MB/AMG's engineers would have accounted for this.
Old Feb 3, 2009 | 06:27 PM
Merc63's Avatar
C63 AMG
Maybe that's why you burn so much oil??
Old Feb 4, 2009 | 09:46 AM
blownS's Avatar
'12 CTS-V
Got the message again today.
Old Feb 6, 2009 | 07:35 AM
1st amg's Avatar
SLS Irridium silver,2014 GL350 BT Irridium, 2015 White Dodge RAM Hemi Quad
I had to add oil last night, about half a quart, light came on, ggod thing I have one in the trunk, I am at about 5000km, did my oil change at 1600km, so probably due for another anyway.
