C63 Suspension Too Rough...
I like everything about the car so far except the suspension. But my complaint is probably different from most of you here - I want an option of a softer ride in normal situations. I'm in Seoul, Korea and most of the side roads are quite bumpy, so you can imagine with the tight suspension on the C63 the ride is quite rough.
Since I had a Lexus GS430 before this, I probably have gotten too used to the softer ride of Lexus, but don't some of you think under normal driving conditions the C63 ride is too rough? I don't even have the Performance Package but still quite rough.
It's unfortunate that the C63 does not have Airmatic adjustable suspension like the E63 or CLS63, although I wonder if even the Soft setting of Airmatic on the CLS63 is just as rough as the C63?
Anyone know of an adjustable suspension that I can replace the factory suspension with, to have the option of a softer ride when I want it?
Thanks!
2. Check the tire pressure https://mbworld.org/forums/c-class-w...-surprise.html
3. Bilstien will release the PSS suspension system for C63
And here we have the coil over press release: http://carlsson.de/carlsson/en/news/...rk_CK63_EN.php
Here is the C-Class PDF (unfortunately only in German): http://carlsson.de/carlsson/pdf/down...pekt-WS204.pdf
seriously it's hard to compare GS430 to the c63 because well it's just such a different focus on the car.
as you know the suspension on the gs is geared towards comfort not sport. the c63 is towards sport, but remember AMG stock suspension is notoriously pretty bad compared to an aftermarket one, no matter what model AMG in the past/present (except air rides ones).
i'd say give it time. you're not used to the new ride just yet, when you drive a car for a while you get used to it, when you make the change and it's different everything jumps out at you and your mind says this is wrong settings etc...when in fact you're just too used to the old car, your body/mind hasn't adjusted.
excuse my poor construction here trying to explain (not enough coffee yet ;p)
