*NEW* Evosport 2-piece Rotors for C63 AMG
#55
They are already out: http://www.evosport.com/product/prod...VO.BRK.M11.RR1
#58
Anyone know this answer? If its just the rotor can you replace them with the quite stock c63 one piece?
#59
The calipers are the same on non PP cars, and P30/31 cars. Not sure on part #'s, but I know Evosport can get you the AMG 2-piece as well. But may as well go with their new, lighter 2-piece
#60
Ok so If I bought a used c63 with the p30 package(mainly for the lsd) and wanted to use the regular c63 one piece rotor its possible,right. What about the sensors? The two reasons why I would do this would be 1-more affordable and 2-they wouldnt squeak when they are cold.
#61
Does your P30 have 2-piece front rotors now? And you want to downgrade to 1-pc? Unless you drive A LOT where you're having to constantly replace rotors, stick with the 2-pc. In fact, if you upgrade to ours, you just need to replace the disc and hardware which is about the same price as buying the 1-piece OE. The unsprung weight benefit is worth it.
Also, to clarify your comment, the rotor has nothing to do with squealing. That's a function of the pad. The 2-pc rotors using the same OE pad do not squeal.
