C63 AMG (W204) 2008 - 2015
MHP Quaife LSD GP
Old Feb 17, 2009 | 09:18 PM
YNOT600's Avatar
several
MHP Quaife LSD GP
We need a miniumum of 5 orders. Quaife part #QDF9V (yes it works in the C63 even though that's not it's designated application).
Please PM "YNOT600" for shipping options and pricing.
Thank You
Tony
More info C&P'd below:
No more one wheel burn outs!
The Quaife Limited slip (LSD) Differential for the LX Platform HEMI cars is a real limited slip differential offered as a direct replacement for the factory Open Differential
The Quaife Differential powers both drive wheels under nearly all conditions, instead of just one. With an ordinary open differential, standard on most cars, a lot of precious power is wasted during wheel spin under acceleration. This happens because the open differential shifts power to the wheel with less grip (along the path of least resistance). The Quaife, however, does just the opposite. It senses which wheel has the better grip, and biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel.
In drag-race style, straight-line acceleration runs, this results in a close to ideal 50/50 power split to both drive wheels, resulting in essentially twice the grip of an ordinary differential (they don't call open diffs "peg legs" for nothing).
In cornering, while accelerating out of a turn, the Quaife biases power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed.
The Quaife also controls loss of traction when the front wheels are on slippery surfaces such as ice and snow or mud, providing the appropriate biased traction needed to overcome these adverse conditions. The Quaife Differential provides constant and infinitely variable drive. Power is transferred automatically without the use of normal friction pads or plates seen in other limited-slip designs.
The Quaife's unique design offers maximum traction, improves handling and steering, and puts the power where it is needed most. A definite advantage whether on the track or on the street.
The Quaife is extremely strong and durable and since the Quaife is gear operated, it has no plates or clutches that can wear out and need costly replacement.
The Quaife is great for street driving or racing. Racers don't have to put up with locking mechanisms or spools that created unwanted under steer under power, or in the case of front-drive cars, even tear the steering wheel out of their hands when cornering. Because it behaves like an open differential during ordinary driving, street drivers will have trouble telling it's there until pushing the car's limits.
The Quaife has been proven in everything from SCCA Rally to Formula 1. It provides autocrossers with such an advantage, it has become "required" equipment for a winning effort.
More and more auto manufacturers are specifying the Quaife ATB Differential as original equipment in their high performance models - for good reason - it works!
Installation Time: approx. 4 hours
The Quaife ATB Differential comes with something else other's don't have: a Limited Lifetime Warranty. This warranty applies even when raced!
Old Feb 18, 2009 | 01:15 AM
Untertürkheim's Avatar
I would be concered about the gearing especially if it is not designed for this car.
Do you know the gearing? Also, does it fit all 204 chassis, or only the AMG?
Old Feb 18, 2009 | 08:26 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Well, QDF7V is the Quaife ATB LSD for the C32... and -9V appears to work in the E55's (and, presumably, the E63's) - so I'm not surprised that 9V works in the C63 as well - Quaife's site isn't great about keeping the application guide current. Good luck with the GB!
Old Feb 18, 2009 | 02:58 PM
YNOT600's Avatar
several
You reuse your OEM ring/pinion, the LSD does not come with those parts.
Yes the QDF7V has multiple applications and even though it has already been proven to work in the 55Ks and C63s, Quaife still doesn't list them.
Thank You
Old Feb 18, 2009 | 08:36 PM
c32AMG-DTM's Avatar
Thank You
You mean -9V for your reply (not -7V, which is what we use), but I get what you meant
Old Mar 18, 2009 | 12:07 PM
mthis's Avatar
Anything W/4Wheels
got the lsd tue now going to put it on.
Old Mar 18, 2009 | 03:48 PM
zivicirl's Avatar
C63
mthis... let me know how that goes for you i am debating on getting it.
Old Mar 18, 2009 | 05:44 PM
mthis's Avatar
Anything W/4Wheels
I could not get it done today it's gana be sometime next week. When it's done I'll let u know. I can't wait
